Strange problem with PCV system??
Old Dec 20, 2004 | 10:56 AM
VTC_CiViC's Avatar
Default Strange problem with PCV system??
Relax, this isn't another "what kind of PCV should I use" thread
Here's my situation. On the back of my GSR sits the stock PCV black box. One hose runs to a small vacuum port on the back of the block, the other which contains the actual PCV valve normally hooks up to a vacuum source on the manifold. I went ahead and pluged the hose into the block as normal, but whenver I plug the actual PCV line into the intake manifold, the car reacts like is now has a massive vacuum leak. The idle rises quickly and proceeds to bounce over and over and over non stop untill I plug that line comming off the manifold and the idle will drop to normal, rock steady. Like I said though, this only happens when I connect the PCV to the intake mani, if I just plug that port on the intake mani and leave the PCV hose open to the atmosphere, no problems.
Any idea what could be happening? I guess there's no problem leaving the line as it is now except that the PCV isn't being asisted by manifold vacuum durning non-boost driving, but obviously that's not how it's supposed to work, any help would be apprieciated.
Old Dec 20, 2004 | 09:27 PM
VTC_CiViC's Avatar
Default Re: Strange problem with PCV system?? (VTC_resurected_CiViC)
bump for the early crew..
Old Dec 21, 2004 | 03:36 AM
Teglove2's Avatar
I got that same problem, bump
Old Dec 21, 2004 | 05:03 AM
Boosted2K's Avatar
Default Re: (Teglove2)
The idea is to vent the crankcase directly from the block fittings and eliminate the PCV valve.
I capped the fitting off directly at the intake manifold, removed the black box, plugged the hole that was underneath and plugged the brass fitting directly above it.
I then vent the crank case straight from the 2 freeze plugs on the back of the block to a catch tank with a return line (endyn setup) I have had absolutely no problems with this setup and it eliminates blowby
Heres a crappy pic, if you need a better one let me know
Old Dec 21, 2004 | 06:26 AM
VTC_CiViC's Avatar
Default Re: (Boosted2K)
Yea, looks like I'm just gonna say screw it and go the catchcan route already.
Old Dec 21, 2004 | 06:29 AM
dasher's Avatar
Default Re: (VTC_resurected_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Yea, looks like I'm just gonna say screw it and go the catchcan route already. </TD></TR></TABLE>
treal_atl
Jan 30, 2008 01:26 PM
RiversideS13
Jul 18, 2007 11:08 AM
yeegsr
Nov 10, 2004 09:00 PM
miataguy
Jun 14, 2004 07:43 AM
Nextelbuddy
Mar 26, 2004 05:08 PM
