Strange oil burning problem and compression numbers
Old Mar 3, 2008 | 06:06 PM
Dartanian's Avatar
Default Strange oil burning problem and compression numbers
I have been burning a small amount of oil lately, mostly at low loads. It will boost up to 10 psi and the power feels normal and there is not a puff of smoke behind me but at idle, I can smell it and it will let out a small puff when I give it a little gas but not every time. So I check the intercooler piping and downpipe for any signs that my turbo seals are bad and they look fine. I then run a compression test and the results are not good:
1: 180
2: 120
3: 180
4: 180
To make sure the tester wasn't bad, I ran cylinder 2 again...same result. Then I tried a wet test...same result. I figured broken ring lands but I wasn't smoking out of the valve cover.
I spent Friday afternoon breaking down the engine. The headgasket looked pretty sad since it was a reused one sprayed with copper (but I have a brand new one ready to install), but I wasn't displaying any signs of a bad headgasket. I was surprised when I pushed out the troubled piston and there was nothing wrong with it...the rings looked great and the ring lands were all intact.
So what is the problem? Valve stem seals were replaced within 10,000 miles, valves look good, turbo has less than 3,000 miles on it. I have pretty much decided that I am going to rehone, rering, replace the rod bearings, and headgasket and hope the problem goes away. Any ideas?
Destructive-
Aug 21, 2009 08:24 PM
Dartanian
Mar 3, 2008 08:50 PM
turbo-crx
Oct 10, 2007 09:29 AM
red teg
Oct 9, 2005 03:33 PM
PTR1
Jul 8, 2004 11:29 AM
