Stocker Question
Old Oct 1, 2002 | 05:16 PM
sleepercivic's Avatar
Default Stroker Question
Is anybody here running a B16 stroked out to a 2.0?? if so what do i need to know before doining it, what injectors are gonna be best for about 20 psi, and should i use 3 inch exhaust piping?
TERRY
[Modified by sleepercivic, 6:15 AM 10/2/2002]
Old Oct 1, 2002 | 09:15 PM
Default Re: Stroker Question (sleepercivic)
anybody?
TERRY
Old Oct 1, 2002 | 10:36 PM
Vanilla Ic3's Avatar
The block is kinda short. The only way to do it without boring is a 95mm crank, but you'de end up with short rods. You could run 85mm pistons with a b18 crank... Either woul'd limit the high revvving ability of your engine. Probably not a good idea. If you want a 2.0, better to get a CRV block. It's taller. Or get a riser plate. Ya. Or just be happy with the stroke you've got. Even better.
Old Oct 2, 2002 | 12:38 AM
BudaKai's Avatar
Default Re: Stroker Question (Vanilla Ic3)
Where can I purchase a Riser(deck) plate or is that something I'm gonna have to make myself?
Old Oct 2, 2002 | 05:19 AM
Dutchie's Avatar
If you want you could go to ClubSI and talk to DBallz. He is running a B16 stroked to 2L with 15psi from a 20G turbo.
As for the injectors: It depends on the power more than boost level, but you will need 720s or 850s I think.
Old Oct 2, 2002 | 08:28 AM
Default Re: Stroker Question (Dutchie)
is anybody on here running this setup?
TERRY
Old Oct 2, 2002 | 08:34 AM
falcongsr's Avatar
What is this crap?
talk to Golden Eagle Mfg about deck plates.
Old Oct 2, 2002 | 07:42 PM
Default Re: Stroker Question (falconGSR)
i like the idea of an actual stroker better.
TERRY
EG6 Love
Apr 19, 2009 07:26 PM
theslugbug
Jul 13, 2004 04:56 AM
TylerB
Apr 22, 2004 07:23 PM
B20LS-T
Dec 6, 2001 07:41 PM
