Stock map sensor question.
Old Jun 10, 2009 | 07:44 PM
Mr.Death's Avatar
Default Stock map sensor question.
I know the stock map sensor on my d16z6 is good to around 11 lbs boost right? What happens when you boost higher. Does it stop changing the ignition timing or something?
Old Jun 10, 2009 | 07:47 PM
912's Avatar
912
Default Re: Stock map sensor question.
check engine light comes on and wont allow you to boost past 12 its like hittin rev limiter or boost cut off
Old Jun 10, 2009 | 07:48 PM
tegman23's Avatar
The stock map sensor wont read past 11psi, after that your car hits a "limp mode" I guess you can say
Old Jun 10, 2009 | 07:52 PM
Mr.Death's Avatar
My car hits 15 lbs on some nights and it pulls like a mother. Happens all of the time. Doesnt seem to affect anything.
Old Jun 10, 2009 | 08:00 PM
93turbo16's Avatar
The car will not hit a boost cut or throw a check engine light.
What it will do is keep thinking the car is at 11 psi and it will keep reading the fuel and ignition values for the last column in the map.
Which is bad news if it was tuned to run 10-11 psi already and you turn it up more..
Old Jun 10, 2009 | 08:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
no, technically your boost cut would have to be set at 10psi or so. depending on how the sensor reads and how accurate your Watergate spring.
i would say 9.5 to give room for boost cut.
Old Jun 10, 2009 | 08:12 PM
Mr.Death's Avatar
Thats what I thought. My cars tune is rich so I guess thats whats keeping it going.
Old Jun 10, 2009 | 08:40 PM
HiProfile's Avatar
Sometimes the knowledge on HT, or the lack there of, surprises me. That's ONLY if you have boost cut set to the limit of the sensor. Otherwise it will just keep telling the ECU it's at ~11psi, while boost climbs, fuel/timing stays the same, and afr's rise.
If it was tuned a bit right with conservative timing as you say MrDeath, it may tollerate some overboosting. However, I never ever suggest people run w/o boost cut active. I prefer ~10psi myself, but I've done 10.9psi for a guy who wanted all he could get. Just test it out to make sure it works, since each sensor is a little different. I know someone who overboosted with a 2.5bar, since his sensor never reported enough psi to activate his boost cut. His gauge showed ~30psi, but the ecu was fueling for ~21psi... It pulled HARD - until it shot a forged rod out the block.
Old Jun 11, 2009 | 06:09 AM
Mr.Death's Avatar
Thanks again. Time to turn down the boost.
MethHeadCrx
Jun 19, 2015 03:22 AM
Hiboost 2.0
Apr 17, 2013 08:14 PM
Kavman
Apr 19, 2009 11:11 PM
GoHybrid
Mar 29, 2009 06:13 PM
the.hamburglar
Aug 2, 2007 02:44 PM
