Stock ITR head for boost?
Old Jun 21, 2013 | 11:00 AM
RevIllusions's Avatar
Default Stock ITR head for boost?
Finishing up by b18c forged internal block for boost and about to conentrate on the head. I have a stock Integra Type R head. Wondering if it was worth upgrading anything, or should the stock head be sufficient. Id rather be spending money on a better turbo than upgrading parts I may not need. Since the head already has dual valve springs and Im keeping the stock ITR cams, I think i should be ok, but I would like to hear from others that have ran a stock itr head.
Planning in running a t3 60-1 at about 15-18 psi.
Old Jun 21, 2013 | 11:53 AM
Muckman's Avatar
Moderator in Chief
Default Re: Stock ITR head for boost?
Upgraded valve springs are cheap and always recommeneded if running high pressure. 15-18psi will be fine for stock springs.
Old Jun 21, 2013 | 11:54 AM
I agree its fairly cheap, but its also almost have way to a ball bearing upgrade. LOL.
Old Jun 21, 2013 | 12:13 PM
digital sol's Avatar
hah buut the ball bearing upgrade isnt going to help prevent your engine from eating itself!
Old Jun 21, 2013 | 12:39 PM
SiRCiviC94's Avatar
It's fine 400hp all day
Old Jun 21, 2013 | 01:16 PM
Runnerdown's Avatar
I would change the springs. You can get away with stock but the oem valvetrain is getting old and good valve control at higher rpm will be questionable.. Springs are cheap, just do it.
Old Jun 21, 2013 | 09:07 PM
blackeg's Avatar
i would possibly replace the retainers with something else before the springs, but overall while its apart its just best to replace springs and retainers. the head will do fine with that 60-1. im running pretty much that same setup and also a journal bearing garrett 60-1.you can see my times and power in my signature
Old Jun 22, 2013 | 02:50 AM
TravisBiggie's Avatar
438whp on 16psi, what kind of motor?
Old Jun 22, 2013 | 10:52 AM
blackeg : What A/R are you running?
Old Jun 22, 2013 | 11:49 AM
wantboost's Avatar
Who is Mr Robot?
Springs and retainers have gotten cheap. Real cheap.
Old Jun 23, 2013 | 06:25 AM
blackeg's Avatar
84.5 mm gsr block with a b16 head(itr cams) and ls crank.
the dyno was done with a .82 ar. i have since switched back to a .63 to pick up a bit more responsiveness. i might have lost a few hp up top but picked up some midrange increasing the average hp. i gained 1-2mph on pretty much the same boost level swapping housings.
all dyno work done on a dynojet
captivahach
Aug 4, 2009 12:29 PM
Trak_Day
Dec 29, 2003 10:49 PM
servion
Oct 20, 2002 10:37 PM
Markaccord95
Jan 28, 2002 10:43 AM
bigTom
Jul 26, 2001 11:08 AM
