Stock internal b18C GSR...good or bad for turbo?
Right now I have the jdm gsr b18C in my car with the LSD S80. Right now got full straight pipe exhaust to a Flowmaster muffler. I have a 1st gen intake mani ITR rep from Skunk2. 255L pump aem fuel rail with rdx injectors. Currently put down 170 all motor. I believe I should be able to run 8psi no problem but correct me if I'm wrong and steer me in the right direction. First turbo build guys. Thanks in advanced!
I never narc'd on nobody!
Re: Stock internal b18C GSR...good or bad for turbo?
Read the FAQ's sticky. Eat dinner, then read it again. Print it out. Go to sleep, wake up, and read it a third time while you're eating breakfast. Have your favorite actor record it in audio form, and listen to it on your way to work tomorrow.
For starters, PSI means nothing. 8 PSI through a T15 will make funny noises. 8PSI through a GT90 will turn your motor into a work of modern art.
I made 340whp on a bone stock gsr.
these motors can take a beating if tuned right.
Do yourself a favor and run e85 if its near you
if not run a safe amount of timing, build the head(keep your stock valves) and install arp head studs.
other than that bolt on a 18g or gt30 and shoot for 350whp.
importman1
09-24-2007 07:20 PM
