stock injectors and 100 shot
I'm debating running a 100 shot of nitrous (dry) on my H22 tuned via hondata and using their nitous control option. everything else will be basically stock except exhaust and I might add a header if I can convince myself the money for one is worth it. My question is, are the stock injectors big enough?
Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">440's at least. 550's would be better.</TD></TR></TABLE>
550's
550's
Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">a buddy did 100 shot wet direct on stock h22a injectors with hondata
just make sure you use race gas </TD></TR></TABLE>
i'm doing 150 shot direct port on stock b16 injectors................but then again your injectors have absolutely NOTHING to do with a wet nitrous setup
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">wet system would be ideal. dry and 100 shot...um no.</TD></TR></TABLE>
a 100 shot dry with a hondata system is a better setup than a 100shot single fogger in my opinion.
but if you're serious about trying to make power on nitrous, you wouldn't even be thinking about a fogger setup anyway
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">dry and 100 shot...um no.</TD></TR></TABLE>
Why not? I've done it on my D16.
because the optimal setup would be a direct port wet setup. a single fogger will not distribute the nitrous or fuel evenly to all the cylinders which is
-harmful to the cylinders as one or two will be getting the full brunt of the power and the other 2 wont get any.
I'm sure you have a built motor, if you don't you'll need one real soon. but then again your motor is probably tuned very well.
I still woundnt recommend anything over 50 hp as a dry shot.
IMO 80+ needs a direct port (wet) setup for optimal power and long life.
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">because the optimal setup would be a direct port wet setup. a single fogger will not distribute the nitrous or fuel evenly to all the cylinders</TD></TR></TABLE>
Sure it will. The nozzle must be placed at least 18" from the throttle body and the intake manifold will distribute the nitrous evenly like it's supposed to.
u understand what you're saying, but puddling can still occur and the honda intake mani isnt the greatest design (side entry) hell if it works for you, great, but i wouldnt do it.
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">u understand what you're saying, but puddling can still occur and the honda intake mani isnt the greatest design (side entry) hell if it works for you, great, but i wouldnt do it.</TD></TR></TABLE>
You get puddling from a wet kit, not a dry kit.
NathanMorris
12-09-2004 11:57 AM
