stock fuel lines
Old Feb 24, 2009 | 07:50 AM
bigbeckster's Avatar
Default stock fuel lines
OK, I am starting a build and I am not sure on a couple of things. I am looking to get around 450- 500+ e85. Now can I use stock fuel lines? if not what do you prefer? I have not done a lot of research on turbos. Kinda the last thing I am thinking about at the moment. Will the garret gt35r turbo make my power goal? Thanks for the input.
This is going in a 96 Ek
My setup
Block
Benson Sleeved 83mm Block
Benson Balanced and micro polished crank
Cp Pistons and rings
ARP Head Studs
Manley Rods
OEM Bearings
OEM oil pump
OEM water pump
Head
Port and polished Head
3-Angle Valve Job
1000cc precision Injectors
Ferrea Valves
Ferrea Retainers
Silicone Bronze Valve Guides
Ferrea Rockers arms
OEM head caps
OEM Bolts
Transmission
GSR with OBX LSD
carbine Coated Scyros
SPEC Stage 4 Clutch
OEM Axles
Turbo
garret gt35r turbo
Precision AS1025 600HP Front Mount Intercooler
HKS SSQV BOV
Tial 44MM Wastegate
Misc
Victor X Mani
70mm throttle body
Walbro 255
Old Feb 24, 2009 | 07:57 AM
Ls_dx's Avatar
Default Re: stock fuel lines
Sounds like a nice setup.
35R should easily make that power. I dont know about e85..? But people have made 600 ish on stock fuel lines. Lets see what some of the gurus have to say *cough* blundar *cough*
Old Feb 24, 2009 | 08:12 AM
thank you, I am about 95% there. A lot of money. But I would like to get some other people opinions!
Old Feb 24, 2009 | 01:19 PM
no one has anymore input on if I need to upgrade my fuel lines from stock to something else. Recommended things to do? anything?
Thanks guys
Old Feb 24, 2009 | 01:32 PM
96 GSR-T's Avatar
Your fuel system will be maxed out with a 255hp and 1000's at 500hp with E85, the OEM lines will be fine but if you want to upgrade them do it, I doubt it will make a difference at your power level.
I recommend the ID/Bosch 1000cc Saturated and adding a Bosch 044 in addition to your intank walbro, that will be enough fuel system with 100psi of base pressure for 600hp on E85.
Old Feb 25, 2009 | 07:09 AM
alright sounds good. I will make that change.
92egkirt
Dec 5, 2011 02:09 PM
Ride Da Fire
Sep 8, 2011 02:12 PM
MONSTERek4
Jan 7, 2010 12:14 PM
DA TeG 90
Nov 8, 2009 06:21 PM
477whpteg
Mar 19, 2008 08:38 PM
