higher HP d16 guys. help please
Old Feb 22, 2009 | 10:38 AM
big-cat's Avatar
Default higher HP d16 guys. help please
what kind of motor mounts are you guys running? I hear innovative are good but should i get the whole mounts or just inserts?? kind of need advice/oppinions
I am a college student with not to much money. btw the build should be done over spring break(early march) this and the exhaust piping are the last things i need.
thanks in advanced
Old Feb 22, 2009 | 12:04 PM
SovXietday's Avatar
Default Re: higher HP d16 guys. help please
I will be switching to Innovatives sometime this year, I currently have stock with poly inserts. The EK driver side blows and the engine still moves pretty bad.
If you can source the money or maybe try and find a used set of decent mounts it would be your best bet. Also, the transmission and AC torque style mounts help a lot too so you could always fabricate something to do their job better.
Old Feb 22, 2009 | 12:16 PM
blue_hatch's Avatar
window weld, used it for my lower engine mount and lower tranny mount. big difference! and ony $11 at autozone
Old Feb 22, 2009 | 12:46 PM
SovXietday's Avatar
You have an EG, EKs have that stupid pillowball mount on the driver side that demands replacement.
Window weld can be used on the other ones I suppose though.
Old Feb 22, 2009 | 02:01 PM
Ls_dx's Avatar
I like my innovative mounts.. and OP, CHANGE YOUR OIL LOL
Old Feb 22, 2009 | 04:44 PM
big-cat's Avatar
no way will i change my oil lol not for this stock motor.
So window weld. I will look into it. what is it exactly?
ok here is a little update on pics i got today.
just a teaser/shitty pics.
Old Feb 22, 2009 | 05:14 PM
Boosted_B_Series's Avatar
If you are goin to run window weld.. window weld inserts into the stock mounts.. Works great.
We weld are mounts up however
Old Feb 22, 2009 | 09:11 PM
N2HIFI's Avatar
op switch your dr side pillow mount to the integra style , youll need a integra motor side mount but it bolts up just fine.
Old Feb 22, 2009 | 09:25 PM
big-cat's Avatar
so is window weld a type of insert? or does it like harden the stock inserts?
Old Feb 23, 2009 | 06:06 AM
Andr3w's Avatar
^ i use polyurathane window cocking as well (window weld)
What i do is clean my mount with thinner very well.
Tape one side of the mount and then fill it packed from the other.
let it dry then voila.
Old Feb 23, 2009 | 08:39 AM
LurkerS8's Avatar
I have mild steel inserts welded onto my stock mounts. Its stiff as hell but still has the tiniest play so its not wearing down axles.
Old Feb 23, 2009 | 12:28 PM
Ls_dx's Avatar
Yea window weld is the clear slilcone stuff that dries to a hardned hardness.. you can get it at walmart and it comes in a caulking tube. just take your stock mount and fill er up and let her harden then BAM you have home made stiff mounts
Old Feb 23, 2009 | 01:14 PM
big-cat's Avatar
will it break down though over a period of time? i dont want to replace it after a year lol. if it lasts more than 5years it sounds like it would be worth it if not i would just go with mounts. how bout the vibrations. This is going to be my DD btw till i get another DD. thanks for the help to everyone.
Old Feb 23, 2009 | 05:38 PM
same ol Steve's Avatar
FAIL ALERT !!!!!!!!!!!!!!!!!!!!!!!!FAIL ALERT!!!!!!!!!!!!!!!!!!!!!!!!!!!!FAIL ALERT!!!!!!!!!!!!!!!!!
Window Weld is a brand name made by 3M and is a type of urethane adhesive used by auto glass shops to "glue" new windshields in when they replace them. It is BLACK not clear.Be careful when you use it because it gets everywhere. There are several companies that make it, Sikkens,Sika etc
ps I know this since my wife owns an auto glass shop.
Old Feb 23, 2009 | 05:51 PM
da_dude's Avatar
Innovative mounts here with the 75a insert.
Old Feb 23, 2009 | 05:56 PM
redex04's Avatar
I have motor mount inserts window welded in and my mounts are super solid.
Old Feb 24, 2009 | 05:40 AM
big-cat's Avatar
ehh idk I hear it breaks down fairly quick. that is the only problem i would have with it.
Old Feb 24, 2009 | 08:08 AM
Ls_dx's Avatar
LoL you havent changed ur oil in 20K and your worrying about your window weld breaking down!!
just call innovative up and get some real mounts
Old Feb 24, 2009 | 09:37 AM
big-cat's Avatar
I have a built motor on the side. i am seeing what i can get out of the stock one . Yea i think i am just going to go ahead and get the motor mounts. on the new motor set up i want to do everything right. as for the stock one i want to see what it is capable and how much abuse it can take.
Old Feb 24, 2009 | 11:32 PM
KENetics1's Avatar
is there a difference between aftermarket steel & aluminum mounts besides cost, does one do a better job? Looking at the innovative mounts with 75a insert, trying to decide steel or aluminum.
Old Feb 25, 2009 | 06:06 AM
ReDemoN's Avatar
DixielandImports Please
Innovative here.
Motor doesnt move at all.
Old Feb 25, 2009 | 07:48 AM
big-cat's Avatar
I am more so looking for the best combo of the motor not moving and so my car doesnt shake like a ****.
saemoonyang
11
Nov 3, 2011 12:33 PM
jclamor87
Nov 5, 2007 02:36 PM
justseeingifitistaken
Aug 20, 2006 09:44 PM
Nova_Dust
Jun 6, 2005 06:16 AM
wizzards581
Apr 8, 2004 09:23 PM
