Stock Block H22?
A few years ago I ran a fmu and 8psi on my h23a with no problems. I wouldn't go any higher then 9psi on a stock block if this is your daily driver and you want the motor lasting for a long time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">A few years ago I ran a fmu and 8psi on my h23a with no problems. I wouldn't go any higher then 9psi on a stock block if this is your daily driver and you want the motor lasting for a long time.</TD></TR></TABLE>
12:1?? I'm going to boost about 7-8lbs only. I'm contemplating on whether I should go with the VAFC hack or a FMU. This will be on a daily drivin h22. So...VAFC hack or FMU??
Yep 12:1.
I would prefer the AFC hack over the fmu anyday... given that you actually tune it for the hack instead of entering in random %'s people tell you that 'should work.'
I was only goin to run 7 psi always untill i get a rebuilt bottom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">The VAFC hack does away with the need to increase the fuel pressure; so an FMU w/ the VAFC hack would be worthless.</TD></TR></TABLE>
so just go with the VAFC and the 6BTM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">
so just go with the VAFC and the 6BTM?</TD></TR></TABLE>
Yup.
Yup.
