still overheating
Old Feb 19, 2006 | 03:55 PM
  #26
troyk kms's Avatar
I had a similar problem. My head was warped. The tolerance is .003" in flatness on the head. Mine was out .0035" and overheated all the time. I ground the head flat and everything is cool now. The head may have warped while taking it on and off. Also check the flatness of the block. Putting the block guard in may have pushed a cylinder around a little. Check the block with a straight edge and feeler gauges. I hope this helps. You may also want to try spraying your HG with copper spray. 5 or 6 coats will be fine, and put it on and leave it dry for a day.
Old Feb 20, 2006 | 05:03 PM
  #27
crazy_eddy's Avatar
does it overheat all the time or only when you boost? try to drive the car without boosting and see if you still overheat. if not than i thing i know what your problem is!!
Old Feb 21, 2006 | 07:47 PM
  #28
mugencivic94's Avatar
Default Re: (crazy_eddy)
overheats all the time just not in boost
Old Feb 22, 2006 | 06:07 AM
  #29
Zakar's Avatar
Bah, you probably dont need a rad unless your roadracing.. if anything get a stocker out of a delsol si
Ehron
29
Aug 7, 2022 05:46 AM
raider1qaz
28
Dec 19, 2016 07:20 AM
96Integ
Mar 29, 2009 06:11 PM
1strdko
Jul 2, 2003 07:11 PM
pelotudo
May 30, 2002 07:13 PM
