still overheating
Old Feb 16, 2006 | 12:09 PM
mugencivic94's Avatar
Default still overheating
ive got a d16z6 boosted with a greddy kit that i just built the motor with eagl rods wiseco pistions, block guard, springs, retainers, and the first time i used a stock hg and apr studs and the head was lifting so i put a cometic hg with brand new arp studs torqued to 82fts and it still over heats but it dont shoot the coolant into the reserve tank like it used to, ive changed the thremostat, ive put a electiric fan that runs constant on it, and i dont know what else to do when it starts to heat up u can turn on the heat and it goes right back down, but ive bled and bled the system to get air out. the only other thing i notice is in the reserve take is like dirt in the coolant, could my radiator be clogged and rusty or what i really need help bc im tired of swapin parts and buyin **** and it still not workin
Old Feb 16, 2006 | 12:15 PM
HennessySoldier's Avatar
Default Re: still overheating (mugencivic94)
does the lower radiator hose get hot?
Old Feb 16, 2006 | 12:16 PM
Default Re: still overheating (soflab18cturbo)
it gets warm not anywhere near as hot as the top one
Old Feb 16, 2006 | 01:13 PM
bump cause i need help
Old Feb 16, 2006 | 01:19 PM
1.8turbolsvtec's Avatar
what kind of block gard
Old Feb 16, 2006 | 02:19 PM
Weq's Avatar
Weq
block guard
Old Feb 16, 2006 | 05:02 PM
Default Re: (Weq)
who makes it i had a newforms had to drill more holes because it was over heating
Old Feb 16, 2006 | 06:48 PM
Default Re: (1.8turbolsvtec)
its made by kms
Old Feb 16, 2006 | 07:44 PM
Mugencrxsir1's Avatar
Default Re: (mugencivic94)
It should'nt be the KMS block guard, they have plenty of holes for coolant, unlike the neuformz. When's the last time you flushed the system? Also maybe it's time to test your fan, temp sensor, and possible upgrade to an aftermarket radiator.
Old Feb 16, 2006 | 08:00 PM
Default Re: (Mugencrxsir1)
flushed it today see the thing is in the coolant theres this brittle specackle **** in it even after i flushed it completely out with a water hose in the block and the rediator, the fan is a 14inch electric fan that i have constantly runin so i know its on any other ideas?
Old Feb 16, 2006 | 08:12 PM
komat's Avatar
did you put a new waterpump with the new build?
Old Feb 17, 2006 | 12:08 PM
Default Re: (komat)
yep straight from honda everything was new and oem
Old Feb 17, 2006 | 12:13 PM
YiNYaNg's Avatar
Get a dual core radiator
I've never over headed again after installing my dual core radiator
Old Feb 17, 2006 | 10:54 PM
spoonhatchblack's Avatar
Default Re: still overheating (H-T)
Had the same Issue On my Old Motor B16
What Bad Memo's...
Leave your Heater on Full Blast
Well Basically (What I did) Leak the Rad. from the OE Drain (Bottom of Rad.) Start the car on... Disconnect the Top Radiator Hose and Run a Constant Water Hose (To get all those annoying air bubbles out 100%) ...
Connect the Upper Hose back and...Flush the Hose at the Fire wall...
Shut the car off Close the drain cap..ADD 50/50 Anti/Aqua
If this does not work..Then Possibly be your OE RAd. or Rad. cAp.
Hopes this Helps
Old Feb 18, 2006 | 02:52 PM
Default Re: still overheating (spoonhatchblack)
today i noticed it pushin out coolant again i had a guy at acura replace the hg and watched him do it he did it right and over torgued the arp's to 82 ftlbs so is it the hg agian or the block gaurd or what this **** is soo agravatin
Old Feb 18, 2006 | 04:33 PM
Zakar's Avatar
who installed the block guard?
Old Feb 18, 2006 | 04:43 PM
W C L's Avatar
Default Re: (Zakar)
bad radiator cap?????
Old Feb 18, 2006 | 04:50 PM
beerbongskickass's Avatar
Default Re: (Zakar)
What did you origianlly torque the ARP's to with the OEM hg? You can't reuse them after going past 65 ft/lbs because they will strech, so that's why your overflow is probably filling up again. I didn't a lot of research on torquing your hg down before replacing mine and I got mixed results from very experianced builders on this board. Some go by stock and some go higher (50-80). I only did mine to 65 ft/lbs.
I would also ditch the block guard because it will do more harm than good, they are useless and won't save your block if it blows, good tuning will. I'd go back to the OEM hg as well if you haven't already. What kind of fuel management are you running? Sounds like you need a better tune and back the timing down a bit.
Old Feb 18, 2006 | 05:28 PM
JDM00SI's Avatar
Default Re: (beerbongskickass)
ive heard negatives about block guards.
Old Feb 18, 2006 | 06:17 PM
JDM00SI's Avatar
how long does it take to overheat?
Old Feb 18, 2006 | 06:20 PM
N20civicB18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soflab18cturbo &raquo;</TD></TR><TR><TD CLASS="quote">does the lower radiator hose get hot?</TD></TR></TABLE>
What if it doesnt?
Old Feb 19, 2006 | 12:20 PM
Default Re: still overheating (N20civicB18)
took the thermostat out and it dont overheat what does the sensor on the back of the thermostat housing do ? does it tell it when to open?
Old Feb 19, 2006 | 01:59 PM
W C L's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 &raquo;</TD></TR><TR><TD CLASS="quote">took the thermostat out and it dont overheat what does the sensor on the back of the thermostat housing do ? does it tell it when to open?</TD></TR></TABLE>
thermoswitch.... grounds it self out when a certain temp is reached and turns the fans on
Old Feb 19, 2006 | 02:13 PM
Default Re: still overheating (WCL Motorwerks)
ok well if it runs fine with out a thremostat what do i need to do &gt;? the fan aint an issue so what is my next step
Old Feb 19, 2006 | 02:24 PM
YiNYaNg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 &raquo;</TD></TR><TR><TD CLASS="quote">ok well if it runs fine with out a thremostat what do i need to do &gt;? the fan aint an issue so what is my next step</TD></TR></TABLE>
Install a new thremostat and install a dual core radiator too while you're at it since you'll going to be needing it in the long run.
