steps to seat piston rings?
Old Feb 9, 2005 | 02:23 PM
1.8's Avatar
1.8
Default steps to seat piston rings?
what are they? i did a search and only came up with how long it takes to seat.
Old Feb 9, 2005 | 02:46 PM
dustin's Avatar
Default Re: steps to seat piston rings? (1.8)
Crosshatch cyl walls during build up
Use non-synthetic oil first 1000 miles
Don't drive at constant RPM for the first 1000 miles (keep varying speed on freeway, etc).
Always worked for me.
Old Feb 9, 2005 | 04:16 PM
1.8's Avatar
1.8
Default Re: steps to seat piston rings? (dustin)
on CSI, some guy said he does this...
"rev it up to around 3000, let the engine slow itself down, then up to 3500, slow down, 4000, and rinse and repeat."
is that right?
Old Feb 9, 2005 | 04:20 PM
boost fed ls's Avatar
that will work also
Old Feb 9, 2005 | 06:43 PM
1.8's Avatar
1.8
Default Re: steps to seat piston rings? (boost fed ls)
so how long do i do the rev method for? after that, how do i drive? normally?
Old Feb 9, 2005 | 07:25 PM
j-robsDA's Avatar
bump, cause I want to know also... how long?
Old Feb 9, 2005 | 11:48 PM
Garcia-Racing's Avatar
check this.
https://honda-tech.com/zerothread?id=878397
Old Feb 10, 2005 | 04:14 AM
forgotmypassword!(OTT)'s Avatar
BREAKIN - very good info forget about 1000mile breakin!
CHECK THIS OUT! SECTION 4.
Modified by forgotmypassword!(OTT) at 5:32 AM 2/10/2005
Old Feb 10, 2005 | 09:11 AM
WadeH's Avatar
Like most of them said you want to rev the car to about 3000 and them let it slow it self down.
Old Feb 11, 2005 | 01:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">what are they? i did a search and only came up with how long it takes to seat. </TD></TR></TABLE>
The time it takes for rings to seat is relevant to the accuracy/method of the honing process. This varies from machine shop to machine shop depending on the machinary they use. IB has some great info on the sleeving company they use (Golden Eagle)
This can vary with many factors from Stone/Diamond cutting bits on the honing machine through to the cross hatch finish produced.
I highly advise you to read Jeff's writeup on it..
BREAKIN INFO & FACTS TO HELP YOU!
Old Feb 11, 2005 | 01:15 AM
Default Re: (boostedb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb18a &raquo;</TD></TR><TR><TD CLASS="quote">Like most of them said you want to rev the car to about 3000 and them let it slow it self down.</TD></TR></TABLE>
First you want to tune the car for at least part throttle.
You shouldn't baby the engine or beat on it, you should do sweeps up the rev range (one tuned) then as has been said let it spool back down.
Read the above link. or click HERE
taggart_lumpy
Aug 15, 2008 01:02 PM
V8 BAIT
Jul 14, 2004 03:56 AM
gregv
Mar 3, 2004 05:43 PM
crxfanatic
Jul 26, 2002 03:18 AM
90crxzc
May 3, 2002 08:49 PM
