static ignition timing vs fuel management timing
Old Jan 16, 2007 | 05:38 PM
igo4bmx's Avatar
Default static ignition timing vs fuel management timing
I am running a d1y8 and the static compression is 12 degrees BTDC but my Neptune tune its 16.50 degrees.
Will this advance my timing to match my ignition maps? or will i be retarded 4 degreed throughout my powerband?
Old Jan 17, 2007 | 11:06 AM
igo4bmx's Avatar
bump
Old Jan 17, 2007 | 02:49 PM
mtber's Avatar
Default Re: (igo4bmx)
Set your ignition timing to a single value such as 12 deg btdc in neptune by using the lock ignition option along with the service connector. Then set your distributor timing to 12 deg btdc.
You will then need to adjust your timing maps to use a base timing of 12 deg btdc & you will need to tune the car.
Old Jan 17, 2007 | 04:15 PM
2point2's Avatar
Default Re: static ignition timing vs fuel management timing (igo4bmx)
static compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">retarded 4 degreed throughout my powerband</TD></TR></TABLE>
the ecu will think that 12deg is 16.5deg because your 'tdc' set point is physically offset by 4deg retard.
Old Jan 17, 2007 | 05:28 PM
igo4bmx's Avatar
Default Re: static ignition timing vs fuel management timing (2point2)
static compression is 9:1
stock y8 timing is 12 degrees btdc...
since everything is set at 16.50 degrees in neptune, should i assume my maps have to be pulled back 4 degreed everywhere once i lock my timing at 12?
the timing lock is not checked off fyi
Old Jan 17, 2007 | 06:32 PM
HRTuning's Avatar
If you were tuned originally with timing at the distributor set to 16, make sure you move your distributor so it's at 16 otherwise you'll be running retarded. If not, go to preferences and enter 12 as the base timing. The maps will change to reflect your base timing of 12.
L0WL1FE
Mar 27, 2020 02:41 PM
mortificationrock
Jul 10, 2007 04:26 PM
infinate bound
Mar 18, 2004 10:35 AM
97vtec
Sep 23, 2003 10:25 PM
VSM EXtasy
Jul 19, 2003 10:19 AM
