Start-up problem
My fueling and ignition setup is:
- RC 440cc injectors
- Stock fuel rail and regulator
- Crome tuned ECU (OBDI)
- SS blaster coil
During startup, this happens randomly. My idle kinda stutter, and the AF ratio is leaning out a bit (although I am set up for closed loop), if I drive into boost a little here and there, the problem stops, or if I tip in the throttle a bit, the problem also stops momentarily. Sometimes, initial drive, just cruising along the fuel is leaning out also.
Do you think my problem is in ignition or in fueling?
- SS blaster coil
