84.50 b16 with eagle rods, using oil suirters?
DO IT ON ALL FOURS
Re: 84.50 b16 with eagle rods, using oil suirters?
The rods aren't the problem, the pistons usually are. You can work around the problem by bending, twisting, and/or shaving as necessary.
Who is Mr Robot?
The squirters still help regardless if the internals are forged or cast. I try to keep squirters whenever I can.
The biggest issue you'll run into is the pistons probably aren't clearanced for the squirters.
Look at the stock pistons and replicate the clearance on the forged pistons. I've seen people do it with a dremel tool. Just break any sharp edges, you won't effect the strength of the piston.
stevomc51284
05-10-2005 12:50 PM
