sputtering in high boost??
Old Sep 23, 2011 | 11:10 PM
umair's Avatar
Default sputtering in high boost??
i have a turbo b16 that is having some issues at the moment. pretty much when i drive the car on low boost it runs great and does not have any issues at all in boost. but when the boost is at 15-16 psi the car sputters as soon as it hits full boost. any reasons to why this could be happening.
the car made 361whp on 16psi, but when we attempted to turn up the boost on the dyno it did the same thing(19psi). i dont understand why it did this... tomorrow i am thinking about turning the boost down just a bit a to see how it does...any one have any idea about what could possibly be the problem?
the car has id 1000cc injectors so i dont think fuel should be an issue here.
the plugs wires,cap,rotor, and fuel filter were all recently replaced.
thanks
Old Sep 24, 2011 | 04:16 AM
ashb82's Avatar
Default Re: sputtering in high boost??
plug gap
Old Sep 24, 2011 | 07:35 AM
umair's Avatar
i already checked that. they are all at.30.
Old Sep 24, 2011 | 07:46 AM
Hyper16-Johnny's Avatar
Maybe igniter or coil?
Old Sep 24, 2011 | 08:17 AM
SovXietday's Avatar
WAY too big.
Try .025, if not that try .022.
Old Sep 24, 2011 | 04:50 PM
umair's Avatar
ill give it a try but i thought .30 is acceptable.
Old Sep 24, 2011 | 04:55 PM
umair's Avatar
im running e85 too...i dont know if that would make a difference at all or not..
Old Sep 24, 2011 | 05:19 PM
Bugermass's Avatar
your gap is way to big.. Just set it at .016 and be done with it..
Old Sep 25, 2011 | 06:33 AM
dantamparacer's Avatar
either the plug gap or possibly the map sensor. I had a similar issue a few years back and my map sensor was starting to go out.
Old Sep 25, 2011 | 07:28 AM
SpeedwayCoating's Avatar
I would try the plug gap, which is most likely the culprit and then I would look into changing the coil.
Old Sep 25, 2011 | 08:11 AM
hondahusted's Avatar
I would go with plug gap and or dizzy the coil could be breaking up ive seen it a lot of times.
Old Sep 25, 2011 | 08:36 AM
SovXietday's Avatar
Woo that's tiny. You don't have any issues with partial throttle break up with it that small?
Old Sep 25, 2011 | 09:02 AM
h2.4's Avatar
plug gap.
Old Sep 25, 2011 | 10:13 AM
Turbo-LS's Avatar
.030 is acceptable with a real ignition system on stock ignition you have to gap the plugs down quite a bit to no get blow out. For around 20pounds of boost your going to want to be .022-.025 gap. Personally put it at .022 and your done
Old Sep 25, 2011 | 01:41 PM
AllShowNoGo727's Avatar
+1. Had the same problem, regapped the plugs smaller, still breaking up, Went to the honda dealership down the street from the dyno, bought a brand new OEM coil, fixed the problem right away.
Old Sep 26, 2011 | 09:09 AM
Tootsie7944's Avatar
Yea plug gap man....I'm running 23 psi on mine and unless the gap is almost touching I blow the spark out. Gap them tighter and you'll be fine.
If it isn't that for some odd reason, I'd then look to dizzy.
Old Sep 26, 2011 | 07:04 PM
Bugermass's Avatar
Nope..
Old Sep 28, 2011 | 12:51 PM
umair's Avatar
ok guys thanks for the replys. hopefully ill get time to try it out tomorrow. ill keep u guys posted.
thanks
Old Oct 3, 2011 | 08:41 AM
4genaccordfreak's Avatar
What plugs are you using?
if they are slightly larger gap from the package and adjusted to the normal .020-.028" gap for most turbo setups, it is possible the gaps are backing out after several heat cycles. I have seen it before as the cause of high rpm break-up during dyno tuning. changed out for NGK BK--7E and never had an issue after that.
Also check the resistance of your plug wires and for corrosion build-up on the dizzy cap.
Old Oct 3, 2011 | 09:29 AM
turbociv910's Avatar
how old are your plug wires?? most people look over them. need to be replaced every 2/3 years.
Old Oct 17, 2011 | 08:48 AM
umair's Avatar
just an update. i adjusted the gap to .20 and it felt much better!! it still has a slight sputter in high rpms tho at 19psi but at 16 its perfect. before it wouldn't go over 14psi. would changing out the coil fix this issue 100%??
velisma
Apr 22, 2010 11:50 AM
aalb1
Nov 15, 2005 02:09 PM
ATS*Mark
Feb 18, 2004 01:25 PM
