sputtering after track?
Old Mar 28, 2004 | 10:56 AM
vtekthis's Avatar
Default sputtering after track?
after my last pass, the car started to sputter and i was getting a little smoke from the pcv, i checked the plugs, on looks green, but the rest look good, no oil, every cyl is firing, and when you get on it at about 5 grand the sputtering stops and the car pull justa as hard if not harder than it ever did before??? any thoughts?
Old Mar 28, 2004 | 01:25 PM
R THIS's Avatar
Default Re: sputtering after track? (vtekthis)
i dont know abuut your situation, but my car did the exact same thing, smoke from pcv, and a misfire at idle, but higher rpm and boost still felt great... when i took my engine apart, i had broken ring lands
its time for better parts
Old Mar 28, 2004 | 02:04 PM
ITSTOCK's Avatar
Default Re: sputtering after track? (R THIS)
Do a compression check and come back and tell us your #s. Chances are you smoked your ringlands on your pistons, are they stock pistons?
Old Mar 28, 2004 | 11:09 PM
vtekthis's Avatar
Default Re: sputtering after track? (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression check and come back and tell us your #s. Chances are you smoked your ringlands on your pistons, are they stock pistons?</TD></TR></TABLE>
yeah stock pistons. its making me belive not the ring lands, because of absolutely no oil on the sparkplugs aor any in the cyl. with cracked ringland woulend i see a dramatic loss of power? will do a comp test tomarrow to see whats up
igo4bmx
May 14, 2006 08:31 PM
Street Ghost
29
Feb 12, 2006 01:19 PM
blackeg
Jul 18, 2005 12:39 PM
stevescivic
Jun 5, 2004 12:01 PM
done
Apr 23, 2004 06:55 PM
