OK diagnose my car :( HELP
So i most likely have a headgasket issue, but I am not sure if I have a piston issue (whether it be rings or the pistons themselves).
Smoke comes out of my breather all the time (idle or WOT, and in between) - PVC is open dump
Car overflow tank would also fill under boost.
Ok so I have sludge in my overflow tank but does not overheat. However my crankcase looks like oil, and I do not see any white substance in there. I'm assuming that when i boost, my head lifts and oil and carbon (which was also found) go into my coolant.
compression test (with seven cranks) CP 75.5mm 9:1 pistons in a d16y8 motor
1 - 190
2 - 200
3 - 200
4 - 200
My plugs
1 - sludge on threads
2 - normal
3 - normal
4 - normal
Im ready to take my car apart soon, but I am not sure if I need to take the bottom end apart.
Any advice?
1 - 190
2 - 200
3 - 200
4 - 200
My plugs
2 - normal
3 - normal
4 - normal
Any advice?
Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">post your setup...
did you use ARP headbolts?</TD></TR></TABLE>
yes ARP's in a built d16y8 motor...
my sig has the setup
Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">A leakdown test will help confirm the headgasket.....</TD></TR></TABLE>
im gonna replace it.
only thing i'm worried about is that I still have smoke coming out of the breather hole on the valve cover...
Re: (igo4bmx)
could be a blown headgasket but not bad enough that it "plugs up" when the motor get hot.Did you do a compression test while the engine was hot?
Also pressure test the cooling system.Good luck
ILBB
ILBB
Re: (ilikebigbutts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikebigbutts »</TD></TR><TR><TD CLASS="quote">could be a blown headgasket but not bad enough that it "plugs up" when the motor get hot.Did you do a compression test while the engine was hot?
ILBB</TD></TR></TABLE>
When you do the leakdown test you can pop the cap off the radiator and look for bubbles, that will help indicate a headgasket.
At this point you know something is wrong, so might as well pull the head
Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">When you do the leakdown test you can pop the cap off the radiator and look for bubbles, that will help indicate a headgasket.
At this point you know something is wrong, so might as well pull the head</TD></TR></TABLE>
even before i had less than 1% leak on all cylinders... and the coolant would rise...
this is because the head would pretty much seal, when no load it on the motor... but when in boost it lifted
