turbo suggestioN!!
Old Sep 18, 2010 | 05:43 PM
civic92si's Avatar
Default turbo suggestioN!!
okay with my precision turbo i made 317whp @ 10psi.
couldnt figure out whats wrong with it. bought rebuilt turbo kit replace the bearing and the seal along with the snap ring. it still leak oil to the exhaust *notice first time installing the bearing and etc*.
However what should i do?
Buy an new turbo that is the same?
or other?
heres the spec of the turbo i got
# ax. Rated HP 450 Horsepower
# Part No. - SC-5031E
# Compressor Wheel Diameter 54mm
# Compressor Wheel Inducer - 2.123
# Compressor Wheel Exducer 3.000�
# Wheel Trim 50 Trim
# Compressor Cover Inlet 3�
# Outlet Size 2
# Bearing System PTE Race 360 Center Section
# Turbine Housing A/R Ratio - .63 5 Bolt Turbine Housing
# Turbine Wheel Style - T31 (Stage III)
# Turbine Wheel Inducer 2.559"
# Turbine Wheel Exducer 2.229"
# Turbine Wheel Trim - 76
need a suggestion..or should i buy a new one that is the same? budget is 600.00
dont want it 2 rebuild at the shop cuz its gonnna cost me 390 for my shiet to be rebuild @ turbo power. and whats gay about this, is that this turbo lasted me 1 and 1/2 year only!!
Old Sep 18, 2010 | 06:16 PM
TheShodan's Avatar
Moderator
Default Re: turbo suggestioN!!
You need to check your oiling system and make sure
1) You're not overpressurizing the feed with oil over 90 psi
2) there are no kinks or 90 degree AN fittings on the return line (Nice, slow gravity feed is neede)
3) the cartridge itself isn't angled more than 20 degreee from vertical.
Check those first before attempting to rebuild again. If you're overpressurizing, you won't need to rebuild twice. GL.
Old Sep 18, 2010 | 06:45 PM
civic92si's Avatar
naw i angled the same way it was before. =(
Old Sep 19, 2010 | 01:36 PM
TheShodan's Avatar
Moderator
And you checked ALL the others I listed? we want to help, but remember, we're not there with you, so we can't see/hear it all.. Please be thorough in your troubleshooting of the car. That way we can all better assist with ideas to help with your issue.
EKlscoupe_98
Sep 14, 2009 11:55 AM
dephtone
Feb 8, 2009 05:40 PM
TurboTagTeam
Jun 3, 2008 09:39 PM
slow_redcivic
Apr 14, 2006 08:31 AM
stizzit
Sep 6, 2004 07:20 PM
