Spark plugs revisited...pics for you to diagnose with me!
at the jetties fishin'
ok, every 1k or so after a plug swap the car will start to skip up top in rpms when under load. I've always assumed it was the plugs fouling out cause of the greddy blue box I use.
HOWEVER! there has always been these two black streaks on the middle two plugs when I pull them out. At first I thought it was just grease or something from the plug wires or what not.
Anyway, this time I decided to take a look at it further. IT'S ******* electrical burns!! Looks as if something has been arcing on these 2 plugs!!! one just has a small burn, the other one cuts into the porcelain and ends with a visible "electric dusting" on the top of the metal part of the plug.
what could be causing this?? are my plug wires bad?? they're msd 8.5mm wires and I run an SCI ignition and blaster ss coil.
sorry about the pic but my digital camera is HORRIBLE...any pic is better than no pic though.
Re: Spark plugs revisited...pics for you to diagnose with me! (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">any pic is better than no pic though.</TD></TR></TABLE>
Not in this case. Check to see if you have proper ground on the engine.
Re: Spark plugs revisited...pics for you to diagnose with me! (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
Not in this case. Check to see if you have proper ground on the engine.</TD></TR></TABLE>
/cry
well i only took the pic to give a better idea of the scarring...which you can see on the second to left plug...
/cry
stackz
27
02-09-2004 01:13 PM
