breaking up?
Old Sep 22, 2009 | 04:33 PM
turbo gsr2000's Avatar
Default breaking up?
hey i have a 2000gsr turbo and. i think it could be the spark plug wires.... and i want to see what u guys think.. . when i first turn the car on after like 10sec .. i here like a backfire/poping sound ''.. it pop's/backfire ... then when i drive it . when i go WOT right when i hit 6k it break's up nasty but when i am in 2nd i can rev it past 6k but any other gear it wont go past 6k...... what do u guy's think it could be .... cheep spark plug wires????
Old Sep 22, 2009 | 07:15 PM
Default Re: breaking up?
bump
Old Sep 22, 2009 | 08:30 PM
jdm inc's Avatar
what wire are you running? what spark plugs are you running? stock ignition?
Old Sep 22, 2009 | 08:46 PM
i am useing ngk spark plugs .and a MSD Blaster 2 Coil.. idn what kinda of wires i can check later... cuz i am about to go to sleep but... it has the stock ignition.. but the spark plugs wires are old ..
Old Sep 22, 2009 | 09:35 PM
FastEg6's Avatar
Do you even have a tune?
Old Sep 22, 2009 | 09:48 PM
yes i do right now it's tune for 10psi
Old Sep 22, 2009 | 10:05 PM
da_dude's Avatar
Did you gap your spark plug down?
Old Sep 22, 2009 | 10:10 PM
no they were preset
Old Sep 22, 2009 | 10:19 PM
omiehomie's Avatar
Originally Posted by turbo gsr2000
no they were preset
you might be blowing out spark? im running NGK BKR7E's gapped to .030-.032
try that and see if that helps your situation...
i have a gsR too btw
Old Sep 22, 2009 | 10:35 PM
jdm inc's Avatar
How are the dizzy cap and rotor old? new? they also can cause break up.
Old Sep 23, 2009 | 06:07 AM
batboyvaj's Avatar
if your plugs are preset to the stock gap, that's way to big for a boosted setup. lower it down to .028 and see if that fixes your issue
Old Sep 23, 2009 | 06:56 AM
dano88's Avatar
if its not the spark plugs i would lean twards fuel detination....? i had a similuar problem getting into v-tech and then it popping really fast and loosing power and its the fuel detoniating?
Egg Driver
Apr 29, 2010 03:25 AM
banginryder16
Nov 23, 2007 06:32 AM
b16b18
Sep 6, 2006 12:56 PM
Lookincrazy
Mar 7, 2006 01:41 PM
TDRacing
Jul 18, 2002 10:58 AM
