Another Spark Plug Help Thread.
Old Mar 10, 2008 | 07:51 PM
hondamn1320's Avatar
Default Another Spark Plug Help Thread.
i am currently running NGK R5672A-9s and i have a small miss at idle. i have some BKR6E-11s sitting in the garage that i was using before i went turbo. do you think if i threw those on it would cure the miss at idle? i am basically looking for a better all around plug. i heard nothing but good from the BKR7E plug, but what "coldness" should i run? most people say to run between 1 or 2 steps colder. what is the stock "coldness"?
stock B16, skunk2 intake manifold, t3/to4e turbo, twisted ram mani. running a basemap for now.
any and all help is appreciated.
Old Mar 11, 2008 | 07:39 AM
B20luda's Avatar
Default Re: Another Spark Plug Help Thread. (hondamn1320)
9's are FAR to cold for what you have, Use 7's and get it tuned running on a basemap isnt optimal either, also the plugs you are using are race plugs, use resistor plugs... gap them to .024 or so...
Old Mar 11, 2008 | 11:56 AM
Default Re: Another Spark Plug Help Thread. (B20luda)
thanks. i am only running a basemap because there are no reputable tuners in my area. i'd have to drive atleast 6 hours to get tuned. i will be doing this in august though when the funds allow it.
Old Mar 11, 2008 | 02:47 PM
ok just to be sure, i snapped a pic of the box. i was under the assumption that the heat range was part of the number. like BKR7E-7 or was i wrong? are these the right plugs i should be using? i know this seems real noobish but i'd rather seem like a noob and be safe, than sorry.
Old Mar 11, 2008 | 08:23 PM
Old Mar 11, 2008 | 08:26 PM
mike93eh2's Avatar
yes, those are the correct plugs you need.
Old Mar 11, 2008 | 09:02 PM
Default Re: (mike93eh2)
thanks.
Old Mar 12, 2008 | 07:22 AM
Flashmn's Avatar
Default Re: (hondamn1320)
BKRE7E = heat series 7, the heat is the number in the plug code. The number that comes after it -11 like example BKRE7E-11 is the gap number, without a number its 0.8mm and with a number its what the number is, like -11 is 1.1mm
Old Mar 12, 2008 | 09:33 AM
Default Re: (Flashmn)
hm... i did not know that. thanks for the info.
FAmou5
11
Mar 2, 2010 01:16 AM
eg:R
Mar 3, 2009 12:45 PM
planoguy36
Jun 7, 2006 07:29 AM
boosted_b16a
Mar 27, 2005 02:09 PM
Casey
Mar 19, 2002 07:00 PM
