spark blow out using microtech and 6psi
Old Feb 4, 2006 | 04:38 PM
ah789454's Avatar
Default spark blow out using microtech and 6psi update -problem found
hello guys i have a friend that has a 2000 integra type r and he has boosted it. he is using microtech and cant rev more than 7000rpm then the spark starts to cut out. i have heard that the microtech system has a few issues with the ignition system. has anyone encountered this problem?
Modified by ah789454 at 10:21 PM 3/3/2006
Old Feb 4, 2006 | 04:46 PM
Blaze45's Avatar
Brrraaaap!
Default Re: spark blow out using microtech and 6psi (ah789454)
If you havent gapped your plugs closer already, try it. Try .028 and see how that does, when I was only running 7lbs on my B20 I had spark blowout after like the 5th run, I was like WTF my ignition sucks lol. Good luck!
Blaze
Old Feb 4, 2006 | 05:10 PM
maxspeedhonda's Avatar
Default Re: spark blow out using microtech and 6psi (Blaze45)
close your gap up. Mine are at 0.24 right now.
Old Feb 5, 2006 | 06:38 AM
N20civicB18's Avatar
Default Re: spark blow out using microtech and 6psi (maxspeedhonda)
mine started breaking up bad, found my plugs were at .035 set em at .026 and never a problem after
Old Mar 2, 2006 | 01:51 AM
ah789454's Avatar
Default Re: spark blow out using microtech and 6psi (N20civicB18)
Update: we installed a crane CDI, crane dizzy, Crane coil. and its still misfiring.
any one got any ideas.
Old Mar 2, 2006 | 05:58 AM
MoonScryer's Avatar
^^^ Did you set the plug gap down?
Old Mar 2, 2006 | 05:59 AM
tgreaves's Avatar
Default Re: (MoonScryer)
What do the plugs look like? Also what heat range plugs are you running? Is it happening at the same rpm all the time?
Old Mar 2, 2006 | 08:32 AM
freakie's Avatar
Default Re: (tgreaves)
the tuner doesnt know what his doing with it.
i've used microtech to 15 psi on stock ignition and it works just fine.
Old Mar 3, 2006 | 09:42 AM
ah789454's Avatar
Default Re: (freakie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakie &raquo;</TD></TR><TR><TD CLASS="quote">the tuner doesnt know what his doing with it.
i've used microtech to 15 psi on stock ignition and it works just fine.</TD></TR></TABLE>
im starting the think so but it is being tuned by toda australia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">What do the plugs look like? Also what heat range plugs are you running? Is it happening at the same rpm all the time?</TD></TR></TABLE>
plugs look fine. and the gap is set to 0.028 and its starts doing it at 7000rpm. it did this at the same rev range even before the ignition gear was added
Old Mar 3, 2006 | 01:23 PM
ah789454's Avatar
Default Re: (ah789454)
guy we found the problem. here is the quote from my tuner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynodave &raquo;</TD></TR><TR><TD CLASS="quote">Jimmeh is this the same car that I had on the dyno twice and told them to throw the unit at Microtech as it is a common problem with MT8 units and Honda dizzy's.
Regards Dyno Dave </TD></TR></TABLE>
jdm.fanatic
Sep 26, 2009 05:14 AM
champLSinteg
Engine Management and Tuning
Mar 30, 2009 03:25 PM
Integra21
Jun 27, 2007 07:30 AM
dc2b18c1gsr
Dec 28, 2003 06:40 AM
808eg6
Jan 25, 2002 07:03 AM
