... something is just not right... any thought... please help
Old Nov 5, 2002 | 02:39 PM
1.8T_EG's Avatar
Default ... something is just not right... any thought... please help
... did a compression test (might do another one just in case)... here are my numbers
1 : 180
2 : 178
3 : 185
4 : 185
... great numbers, right?... but my car is still not running right... here are some issues:
- burns oil (needs about 1/2 a quart a week)
- burns coolant (need to refill overflow reservoir every 1-2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, but not always, but esp. at wot)
- blue smoke from exhaust (sometimes, but not always)
- light smoke from under the hood (sometimes)
- sometimes hard to keep idle without stalling (stopped happening after going to the darkside)
- lower than expected performance (191whp/165tq, see sig for setup) (i was expecting 220-250whp)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or worn o-ring... or worn valves... or cracked ring lands... or cracked sleeves...
... i have also been told a couple of possible quick/cheap fixes:
- clean out pcv valve
- remove air bubbles from cooling system
- get a new radiator cap (which one?)
... is there anything else i can do beside going all out and rebuilding the motor for crazy boost (dont think i have the $$$ for this, wish i did though)?
... thanks for taking the time to read... any help is really appreciated... thanks...
Old Nov 5, 2002 | 03:34 PM
DeepSi's Avatar
Default Re: ... something is just not right... any thought... please help (1.8T_EG)
The numbers you posted (hp/tq) are not that bad for GSR motor @ 5psi
You might get better answers from a leakdown test. Hope you find it out.
Old Nov 6, 2002 | 08:07 AM
1.8T_EG's Avatar
Default Re: ... something is just not right... any thought... please help (DeepSi)
anyone else?
Old Nov 6, 2002 | 08:09 AM
PM-Performance's Avatar
my guess is headgasket. . . prolly not it, but deff worth checking .
Old Nov 6, 2002 | 09:31 AM
gritsak's Avatar
ide also do a leakdown..then you can know for sure if you need to start taking stuff apart and find the problem
Old Nov 6, 2002 | 09:35 AM
DIRep972's Avatar
Smarter than you
do a leak down.
Old Nov 6, 2002 | 09:36 AM
Prod's Avatar
Default Re: ... something is just not right... any thought... please help (DIRep972)
I'd go for the leakdown test as well...That should point you in the right direction immediately
Old Nov 6, 2002 | 11:41 AM
pbomers's Avatar
Default Re: ... something is just not right... any thought... please help (Prod)
leakdown
Old Nov 6, 2002 | 01:26 PM
boostin GSR's Avatar
Default Re: ... something is just not right... any thought... please help (TinyCRX)
what is leakdown?
Old Nov 6, 2002 | 01:28 PM
Prod's Avatar
Default Re: ... something is just not right... any thought... please help (BoostinGSR)
what is leakdown?
http://www.geocities.com/dsmgrrrl/FA...own.htm#WhatIs
Old Nov 6, 2002 | 02:44 PM
DIRep972's Avatar
Smarter than you
nice link.
Old Nov 6, 2002 | 06:35 PM
Andrew 825SM's Avatar
could be worn piston rings....do a wet compression test where you drop a teaspoon of oil into the cylinder...if it jumps over 30 psi in readings then ur piston rings are worn.
Old Nov 6, 2002 | 06:44 PM
speedworks's Avatar
Default Re: ... something is just not right... any thought... please help (NHB Fighter)
1/2 quart a week sounds like the rings.
bpfergu
Mar 5, 2012 05:27 PM
Hulk_EJ8
Jun 5, 2006 12:43 PM
TekSI
Oct 12, 2005 05:14 PM
1.8T_EG
Oct 28, 2002 08:06 PM
1.8T_EG
Oct 26, 2002 10:50 PM
