Missing link required on 94 RS integra obd1 for turbo?
Re: Missing link required on 94 RS integra obd1 for turbo? (JonnyDanger)
well, i will be running hondata s200 also, if that makes a difference, but what exactly does the missing link do anyway?? what are its benefits??
Re: Missing link required on 94 RS integra obd1 for turbo? (Acura_I-RS)
im not familiar w/ hondata so i couldnt help you with that part . you use the missing link so you map sensor will not read the boost .
Smarter than you
With hondata u do not need a missing link. the missing link is used to block ur map sensor from seeing boost, which would then send a signal to the computer, which would then throw a code. the hondata modifies ur ECU to see boost, therefore it uses the map sensor as a receptor and thus u do not need/or want a missing link.
Re: Missing link required on 94 RS integra obd1 for turbo? (DIRep)
yea, thanks a lot for the help man!!! ive saved about 200 bux today because of stuff like this, and good people helping me out, haha, thanks again guys
BolivianFuego
11-10-2003 12:20 PM
