solution-oil return?
Old Apr 8, 2003 | 06:33 PM
highmilehatch's Avatar
Default solution-oil return?
I recently pulled apart my oil return line setup to start from scratch. However, when I removed the drain flange from the turbo itself, the gasket refused to come off and is sealed onto the turbo. Before I attempt to remove the gasket from the turbo via razor blade, is there any type of sealant I can use between the gasket and the drain flange that will hold and not leak oil? I apologize because these pics are quite big and blurry but anyway, heres what I've got:
Old Apr 8, 2003 | 06:43 PM
evoeone's Avatar
Default Re: solution-oil return? (highmilehatch)
just leave it on there, no reason to take it off if its just gonnna go back on , thats what i did, and its still selaed up good
Old Apr 8, 2003 | 06:58 PM
Mr. Softee's Avatar
Default Re: solution-oil return? (evoeone)
gasket remover or break dust cleaner works
Old Apr 8, 2003 | 07:12 PM
evoeone's Avatar
Default Re: solution-oil return? (94goldjungsr)
why bother taking it off if the oil drain flange is just gonna go back on??? just curious
Old Apr 8, 2003 | 07:16 PM
MotorMatrix.com's Avatar
I am a bad person
honda-bond worked good for me.
B16Civic93
Feb 17, 2006 12:48 PM
toolowsol
Aug 15, 2005 02:02 PM
BlueShadow
Jun 23, 2005 06:14 PM
93TurboSi
Feb 17, 2003 12:28 PM
shadowdawn
Oct 5, 2002 03:37 PM
