solid check engine light
Old Jan 31, 2006 | 06:57 PM
b16ahybrid's Avatar
Default solid check engine light
I searched but came up with nothing.
Ecu: obd-1 p-72 running s100b.
I pulled it out of my last car before selling it, everything ran great no problems no cel...perfect...it came out of a 94 coupe.
I bought a new car 93 cx, with a b18c1. The motor is freshly built, it starts and runs (A tad rough, but that can be from several other factors or the cel)...
I jumped the service plug, turn the ignition and the cel comes on and stays solid, no flashes...Any idea's where to start? What could cause the cel to come on and stay on soild and not flash when the plug is jumped?
Old Jan 31, 2006 | 07:08 PM
ek9vboi2's Avatar
sounds like a bad chip or a bad connection some how.
Old Feb 1, 2006 | 06:30 AM
b16ahybrid's Avatar
Default Re: (ek9vboi2)
Connection with the ecu, or connection internal of the ecu? Thanks
Old Feb 1, 2006 | 06:48 AM
DelSolDon's Avatar
Default Re: (b16ahybrid)
if you have the service connector jumped, it should be solid if there are no codes stored. take out the jumper and it should go away.
Old Feb 1, 2006 | 03:30 PM
b16ahybrid's Avatar
Default Re: (DelSolDon)
I'll give that a try. The cel was solid to begin with and resetting the ecu didn't clear it so I tried to jump the service connector...thanks
I hope it's nothing major....
Ever since I went with hondata I havent been able to pull codes whenever I try....so that part doesn't surprise me, the solid light does
Old Feb 1, 2006 | 03:38 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Connection with the ecu, or connection internal of the ecu? Thanks</TD></TR></TABLE>
if you're still having problems, i'm gonna say its a bad internal connection. one of my buddy's P28's he tried to chip himself has a solid cel. did you do the chipping for the hondata yourself?
Old Feb 1, 2006 | 07:58 PM
b16ahybrid's Avatar
The shop that tuned my car did the chipping,
I'm going to pull the cover off this weekend and take a look inside.Thanks for the help so far...
Old Feb 1, 2006 | 08:44 PM
twkdCD595's Avatar
maybe one of the "options" selected is not the same as with the new setup? I got a solid cel on my basemap chip from something similar... seemed it was something about one of the sensors turned off that I actually needed on.
just a thought.
Old Feb 1, 2006 | 08:54 PM
b16ahybrid's Avatar
Default Re: (twkdCD595)
SO you had a solid light because you were missing a sensor that you needed or you had a sensor that was'nt there before .....i.e like you had a knock sensor when it was removed from the program?
Old Feb 2, 2006 | 06:58 AM
twkdCD595's Avatar
yeah, after doing some checking it was cause they had a knock sensor still turned on when I dont have one and the wrong map sensor selected.
Old Feb 2, 2006 | 06:30 PM
b16ahybrid's Avatar
I'll have to check into that, I know I have a knock sensor on this motor, but i'm not sure If I ran one on my last motor...
Old Feb 28, 2006 | 03:21 PM
b16ahybrid's Avatar
Update:
So I had the resistor in the ecu repaired the ecu was tested and worked fine with their tune....So I hooked up the ecu and it runs like crap...even worse then before....I fixed the mixed up plug (AIT plug)......
So I figured since the ecu was tested and came out good I would convert back to stock and change one thing at a time.
I cliped jumper j1, wired my stock injectors back in and installed my hp fuel pump. I installed the fuel pump only because my fpr was jetted for the higher volume pump and I wanted to eliminate the possibility of starving the motor of fuel due to the large return orifice...
I crank the motor over and it starts up, runs for about 3 seconds and dies....after several attempts to start the motor I get a backfire.....Now the motor wont turn over.
I can hear the fuel pump prime but cant verify the fuel pressure...
I'm thinking that either the fuel pump isn't providing fuel or ironically something happend with the spark (my thought is fuel)....I'm about 1 sugestion away from abandoning this project.....Thanks in advance for any advice or help..
Old Feb 28, 2006 | 04:10 PM
b16ahybrid's Avatar
Default Re: solid check engine light (b16ahybrid)
bump
turbo sol
Apr 2, 2009 05:31 PM
93si-hybrid
Jul 21, 2005 05:01 AM
BseriesHatch
Sep 15, 2004 08:46 PM
nek0
Jul 9, 2003 04:49 PM
h8tred
Jul 7, 2003 08:35 PM
