Solid CEL Issue
Old Apr 27, 2007 | 01:47 PM
  #26
B18EG6's Avatar
Default Re: Solid CEL Issue (ham)
have no idea if this will help at all....
but, use a DMM to check the CEL pin at the ECU connector. Maybe it shorted to something? I believe its a green/orange wire.
like I said, might not help at all
Old Apr 27, 2007 | 02:09 PM
  #27
PPLH8R's Avatar
Default Re: Solid CEL Issue (B18EG6)
ahh just take out the bulb !!!
Old Apr 27, 2007 | 03:29 PM
  #28
BlackCRX's Avatar
heres an idea
MAKE it throw a code
unplug something random like... o2 sensor, tps, iacv ect...
the car should still run, then check the CEL and see if it flashes or not
if it does flash then maybe check the service connect agian and make sure its not shorted
if it doesnt blink a code the trace the wiring for the CEL and see if its wired correctly
Old Apr 27, 2007 | 05:01 PM
  #29
Boosted Chemist's Avatar
Default Re: (BlackCRX)
My friend had a hatch like that, ran perfect just threw a solid cel all the time. We never could figure it out.
Old Apr 29, 2007 | 07:27 PM
  #30
darrinbrewer's Avatar
Default Re: (Boosted Chemist)
i had a constant cel on a car.
i was a itr swap into a 96 hatch, the 3 wire/2 wire iacv problem.
had to unplug a ecu pin and move 1 pin over 1 spot to run right.
the car would buck wildly at light throttle, drove fine other than that
was using a p28/p06 chipped computer with a conv harness
kyang03
Mar 6, 2014 07:31 PM
350znal
Engine Management and Tuning
Feb 25, 2011 01:49 PM
rick_rabies
Aug 24, 2009 06:22 PM
h8tred
Jul 7, 2003 08:35 PM
