Solid CEL Issue
Old Apr 18, 2007 | 04:03 PM
ham's Avatar
ham
Default Solid CEL Issue
Turbo d16y7 in a 93 coupe running a p06 and uber...
I tried 3 ECUs (2 p28s, 1 p06) all have solid CEL with my chip
Tried various different burns and programs... uber 1.66 / 1.70, crome...
Tried no chip in the p06 and still a solid CEL
What the hell else could do it? The car runs fine, but the CEL never turns off as soon as I turn the key on.
edit: tried a stock ECU and it has a solid CEL
Modified by ham at 4:05 PM 4/23/2007
Old Apr 18, 2007 | 04:30 PM
ham's Avatar
ham
Default Re: Solid CEL Issue (ham)
i just tried the ECU in my car and no solid CEL!
its definitely the car!
any ideas?
Modified by ham at 6:30 AM 4/19/2007
Old Apr 18, 2007 | 04:31 PM
abusedhusband's Avatar
did u jump the connector to see if the light is on for a reason. if it doesnt flash at all i would check the wire to the bulb from the ecu. possibly shorted somewhere and just lighting it up.
Old Apr 18, 2007 | 05:28 PM
ham's Avatar
ham
Default Re: Solid CEL Issue (abusedhusband)
nah, that was the 1st thing i thought of, but no its not jumped.
it doesnt flash at all when you have a solid CEL because its bad ECU. thing is... i know the chip and ECUs i tried are good.
any other ideas?
Old Apr 18, 2007 | 08:15 PM
nonvtecD's Avatar
I had an issue like this once before. I chipped an ecu for my friend's GSR and it wouldnt work at all in my car no matter what I tried (solid CEL) and then as soon as we put it in his car it worked perfect. If you clip the jumper in the ecu and does the stock p06 throw a code?
Old Apr 19, 2007 | 02:30 AM
ham's Avatar
ham
Default Re: (nonvtecD)
no codes... solid ECU all the time. its like the connector is jumped and it doesnt have any codes so its just solid all the time.
all the ecus and chips work fine in my car
Old Apr 19, 2007 | 05:07 PM
ham's Avatar
ham
bump!
Old Apr 20, 2007 | 10:12 PM
ham's Avatar
ham
bump again
Old Apr 20, 2007 | 10:15 PM
zerovandez's Avatar
go to autozone and rent a scan tool. that's wut i did
Old Apr 20, 2007 | 10:29 PM
tony413's Avatar
if the lights on are you boosting if so have you tried using a missing link ?
Old Apr 21, 2007 | 06:04 AM
mtber's Avatar
Check your ecu fuse.
Old Apr 21, 2007 | 06:24 AM
nonvtecD's Avatar
Default Re: Solid CEL Issue (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">if the lights on are you boosting if so have you tried using a missing link ? </TD></TR></TABLE>
A missing link is not the answer to any problem
Old Apr 21, 2007 | 08:06 AM
ham's Avatar
ham
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone and rent a scan tool. that's wut i did</TD></TR></TABLE>
some people amaze me on this site.
i actually never thought of checking the ECU fuse... i will do that! AAHHH!!
Old Apr 22, 2007 | 11:43 AM
ham's Avatar
ham
all the fuses are good.... bump!
Old Apr 23, 2007 | 07:48 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">bump!</TD></TR></TABLE>
Old Apr 23, 2007 | 08:07 AM
BlackCRX's Avatar
tried putting a stock ecu in the car and seeing if it throws a solid cel?
Old Apr 23, 2007 | 08:19 AM
perseverance's Avatar
check every fuse in the car using a dmm. then look at the ecu harness and see if u see any shielding from the wires exposed. could be something grounding out. dmm's are a life saver.
Old Apr 23, 2007 | 12:01 PM
ham's Avatar
ham
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">tried putting a stock ecu in the car and seeing if it throws a solid cel?</TD></TR></TABLE>
tried that... solid CEL still owns.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">check every fuse in the car using a dmm. then look at the ecu harness and see if u see any shielding from the wires exposed. could be something grounding out. dmm's are a life saver.</TD></TR></TABLE>
the thing is... theres nothing wrong with the car... it runs fine, its fast, drives fine and everything works... it just has a solid CEL
Old Apr 23, 2007 | 03:13 PM
BlackCRX's Avatar
does the cel ever turn off?
like when you have the key in the second position??
i would check the service jumper wiring agian with an ohm meter
Old Apr 23, 2007 | 03:30 PM
ham's Avatar
ham
Default Re: (BlackCRX)
when you turn the ignition on, the main relay turns on and then off after a few seconds. no matter how many codes you have, the CEL is supposed to turn off with the main relay.
when somebody says they have a solid CEL, it means the light never turns off unless the key is off. this is the problem i am having!
Old Apr 23, 2007 | 03:51 PM
BlackCRX's Avatar
someone correct me if im wrong on this one
but if you have a car with no codes and you jumper the service connecter, do you not get a solid cel ?
that was why im asking for you to check your service connector with an ohm meter, considering you say the car runs fine
Old Apr 23, 2007 | 04:35 PM
sounds like a wiring issue. get a wiring diagram of the service jumper and chase the wires to see if there grounded anywhere.
Old Apr 23, 2007 | 07:09 PM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong on this one
if you have no codes, and you jump the service connector, you will get a solid CEL. im going to spend some time with a dvom and see what i can find. thanks for the support so far.
Old Apr 26, 2007 | 11:40 AM
ham's Avatar
ham
bump please
Old Apr 27, 2007 | 10:35 AM
ham's Avatar
ham
bump again
