SOHC worth putting boost to?
Old Sep 15, 2002 | 10:01 PM
  #26
turbopanda's Avatar
Default Re: SOHC worth putting boost to? (mantic6t9)
Just use the internal wastegate that will come with the kit.. it should be good for 1 bar at tops (14.7psi) probably even more depending on the internal wastegate and how stable it is. Only do your external wastegate when you feel that the internal wastegate can't handle things too well anymore
Old Sep 15, 2002 | 10:02 PM
  #27
turbopanda's Avatar
Default Re: SOHC worth putting boost to? (turbopanda)
I was using an IHI RHF5 ballbearing turbo on my D16Y8, and used the internal wastegate on that for months (at 1 bar) before changing to an external wastegate, because I wanted to boost 18psi daily, and my internal wastegate couldn't take it very well..
Old Sep 15, 2002 | 10:31 PM
  #28
mantic6t9's Avatar
Do you know the trim on the apex sohc turbo? How does it compare to drag and revhard?
SohcEkBoost
Feb 2, 2009 06:15 PM
pliskin679
Nov 24, 2007 03:44 PM
-JSpecEk*9-
Nov 27, 2005 09:16 AM
Zumo
14
Apr 15, 2005 02:44 PM
DMoney
30
Oct 9, 2003 12:19 PM
