SOHC TURBO? would you do it?
ok i want to know if i should fix up my d16y7 motor from my ek. i blow the tranny and need to get a new one. i wish i had the money for a swap but i dont. has anyone done a sohc turbo? and is it worth it? i just want to do it for a while just till i can by school. thanks for the help
Re: SOHC TURBO? would you do it? (JDMEK-9)
Nope never been done before.
A lot of people recomend turboing D series to get more power out of them, its a cheaper alternative to doing a motor swap.
http://www.homemadeturbo.com and searching will help you out a lot with this topic, its litterly been covered to death on here. You can get some decent numbers using the stock internals btw.
i ws going to till i found out that you can only put about 7 puonds of boost to it. it didnt seem worth it to me but of course i got some bigger problems than a turbo(cracked head)
Re: SOHC TURBO? would you do it? (TurboFart)
psi has nothing to do with how much an engine can take a t35 at 7 pounds wont make the same power a gt42r will make at 7 pounds, get my drift? D-series motors (d16z6) can handle a max of around 260whp on the stock internals before they start hsooting out of the side and destroying things. Mind you this is with an amazing tune. Also the way the d-series head it made it can easily have the head lift with boost, just geta MLS headgasket and ARP's and you'll be good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">A lot of people recomend turboing D series to get more power out of them, its a cheaper alternative to doing a motor swap.</TD></TR></TABLE>
but just think if you did a swap and then boost that. thats better imo... drop a b18 or somethin in there, its going to make you feel a lot better in the end
You also have to consider the price of replacement parts for the D as opposed to a B. You can find replacement engines all day long for a couple hundred bucks or so. I recently picked up a D16Z6 with two Z6 tranny's for a hundred bucks.
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkSi »</TD></TR><TR><TD CLASS="quote">but just think if you did a swap and then boost that. thats better imo... drop a b18 or somethin in there, its going to make you feel a lot better in the end</TD></TR></TABLE>
Okay, think about what you just said and this kids budget. If he really wants a forced induction vehicle and he did a swap first, how much longer would it take for him to finally have that turbo or supercharger? A BUTT load longer than if he boosted the single cam. I could spend the 3,000-4,000 it costs for a b18c1 on my single cam and put out probably twice as much power than your b18 would stock.
D series are for racers on a budget. Don't suggest he do a swap if you KNOW he can't afford it.
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote"><---- running 300 whp 271 lbs of tq</TD></TR></TABLE>
You can get 200-250hp to the flywheel on a D16 by tuning carefully and properly. 150-200hp to flywheel on a D15. Of course this is on a well taken care of motor that's running smoothly. Those are the averages I've seen around here. You could probably get less/more depending on your set-up, condition of parts, and tune.
btw, I'll be boosting a D15 before I go to a built D16 or B series.
Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">You can get 200-250hp to the flywheel on a D16 by tuning carefully and properly. 150-200hp to flywheel on a D15. Of course this is on a well taken care of motor that's running smoothly. Those are the averages I've seen around here. You could probably get less/more depending on your set-up, condition of parts, and tune.
btw, I'll be boosting a D15 before I go to a built D16 or B series.</TD></TR></TABLE>
to the flywheel? think again
http://www.forums.evans-tuning...=2017
http://www.forums.evans-tuning...=2860
Re: (Soccerking3000)
Do whats cheaper and turbo the ish out of that D. The info is out there, winter is here so read, read, read, and save your holiday money til spring to fix up your engine.
Go Tigers!
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">You also have to consider the price of replacement parts for the D as opposed to a B. You can find replacement engines all day long for a couple hundred bucks or so. I recently picked up a D16Z6 with two Z6 tranny's for a hundred bucks.</TD></TR></TABLE>
exactly, people are giving d-series away. IMO all the d-series guys should let everyone talk tons of trash about d-series. The better b-series appears to those who are "not in the know" the cheaper our replacment d-series parts will be.
people desperately want b-series. just about every b18a/b/c has been scooped up out of the junkyard as well as every b16. the rarity of these things is what keeps them expensive.
turbo D =
turbo D =
Re: (Bense)
damn thanks to everyone with the good feedback. i wish i had the money for a swap but i think i might jus give my D16 a boost. it still has pretty low miles i think. 55,xxx miles on it. thanks to everyone that gave my good feedback. oh btw i AINT a KID.
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Ok, so I was a little conservative in my ranges
Re: (civic_driver)
i agree the sohc d16z6 is a good cheap motor im building one for less than the cost of a b16 short block and im making twice as much power for the money on a b16......turbo it but i dont like y7's there hondas worst d-series in my opinion....i sell d16z6's if u wanna buy one but if u realy want to stay y7's i got a few parts if ya need em
Go Tigers!
Re: (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">i agree the sohc d16z6 is a good cheap motor im building one for less than the cost of a b16 short block and im making twice as much power for the money on a b16......turbo it but i dont like y7's there hondas worst d-series in my opinion....i sell d16z6's if u wanna buy one but if u realy want to stay y7's i got a few parts if ya need em</TD></TR></TABLE>
there are a lot of d-series worse than the d16y7
think about all the 8valve motors.
if it's 4valves per cylinder, it's got potential. If not, then put a 4valve per cylinder head on. if you can't do this. get a different car.
pushrod sucks
pushrod sucks
http://www.cheapfame.org/Video....wmv
^^thats all the evidence you need
http://
turbod16.com for more info
Modified by DYRcivic at 9:04 PM 11/14/2005
http://
