what else do i need for the greddy turbo kit?
i have a d16z6
i want to buy th greddy kit w/ out the intercooler (ill buy one later)
i plan on running 5 maybe 7 at the track
i think i need a ,blow off valve, and the missing link think so i get no cel codes
what else
gauges, electronic boost controller turbo timer???
is it safe to run 5 psi w/ ni intercooler for a month or so
i tried a search but im still unsure
thanks
[Modified by redline201, 11:12 PM 4/30/2002]
what else
thanks
Re: what else do i need for the greddy turbo kit? (redline201)
if your not getting the intercooler, you don't need anything else...the kit comes with everything you need. don't get a boost controller because you don't want to boost any more than the preset level.
IMO the only thing you need is a blow-off valve in addition to the kit (prevents compressor surge which will prolong the life of the turbo). An intercooler is not necssary for the kit at such low boost. I would recommend you also get a boost gauge to monitor what you're boosting but it is not necessary either. The Greddy kit is a pretty complete kit for running the pre-set boost.
Re: what else do i need for the greddy turbo kit? (HENRY)
you won't need missing link because the black box takes care of that. As stated above, the greddy kit is pretty complete. You'll probably need a clutch and bov. Boost gauges are nice to have also. I have a friend that's been running his setup unintercooled for a year now, no problems.
GoFastHappy
03-17-2004 09:57 PM
