sohc turbo heating problem???????
i have a d16y8 in a 93 h/b and every time i go up hills or drive for a long time the temp goes past 220.
d16y8
vitaras
scat rods
spa topmount
ebay t3/t4
brand new water pump
brand new slim fan
no thermostat
stock rad
d16y8
vitaras
scat rods
spa topmount
ebay t3/t4
brand new slim fan
no thermostat
stock rad
Agreed........head gasket.......if your resavor bubbles b4 it overheats then you have hg problem......and you should put the thermostat back on.......the coolant is not absorbing heat if the water keeps flowing......
Search the overheating threads. They are a plenty! This is what you will find, add a block off plate to re driect air flow to the rad, Get a shrouded fan, make sure fan is blowing in correct direction, add a thermostst, add water wetter, bleed coolant properly.
hollums2k
17
Oct 17, 2010 04:17 PM
54
Nov 20, 2008 12:39 AM
Jwbetley
Jun 18, 2008 07:37 PM
