Sohc Problem
Old Mar 16, 2003 | 03:47 PM
TurBoXBirD16's Avatar
Default Sohc Problem
Hey guys,
i was boosting pretty hard on my sohc in third and fourth
then suddenly i dont' feel boost at all, so i thought probably one of the couplers on my charge pipes went loose, but checked today, all the charge pipes are secured
So what can be the problem??
even now I am at WOT, i feel no boost all, but the boost gauge still reads 6 psi of boost..
what can happen?
thanks
Old Mar 16, 2003 | 04:12 PM
T-sohctec's Avatar
Default Re: Sohc Problem (TurBoXBirD16)
50$ says you blew a pipe. did you check every single connection. pull your bumper and check.
hope it aint serious.
Old Mar 16, 2003 | 04:18 PM
BoostedED9's Avatar
Default Re: Sohc Problem (T-sohctec)
pressurize your charge pipes and see if theres a leak somewhere, i found a big one on mine a while ago and decided to do a test and found it..
Old Mar 20, 2003 | 07:31 PM
Default Re: Sohc Problem (BoostedED9)
i checked all my charge pipes, they are all fine..
sowhat can happen??
thanks
Old Mar 20, 2003 | 07:35 PM
Drew Peacock's Avatar
Clutch is probably slipping??
Old Mar 20, 2003 | 07:52 PM
Default Re: Sohc Problem (turbozxi)
i have ACT EXTREME PP with Action 6 puck
thanks
LST2
Nov 15, 2005 10:09 AM
Po0r LiTTle CoUpe
Oct 15, 2005 10:39 PM
turbotime
Sep 26, 2005 06:22 AM
yellowturbo
Oct 8, 2003 09:29 PM
snake01
Jul 28, 2002 09:50 PM
