Boost problem... weird...
Old Oct 6, 2003 | 07:53 AM
yellowturbo's Avatar
Default Boost problem... weird...
Hi ! My aem ems is set at 15 psi on a GM boost solenoid...
But now ( for a few weeks ) my boost goes to 15 psi and then drop to 13 psi ????
I had a high flow 3 inch catalyser... but I dont remember if this trouble occur before ??
Is it possible that my rings are so bad that the boost goes by there ?? I know that I have to change them... I done a leak down test...
Thanks for your help...
OHHH and when it is cold outside the boost reach 17 psi and then drop to 15 ??? WHY !!! WHY !!!
Old Oct 6, 2003 | 08:20 AM
TTT
Old Oct 6, 2003 | 08:47 AM
CiViC SiR's Avatar
Default Re: (yellowturbo)
did you checked your piping for air leak
Old Oct 6, 2003 | 09:21 AM
yes and there is no leak... I will look more in a few week I have to get the engine out off the car ... but I dont think that the problem is that ...
Old Oct 6, 2003 | 01:22 PM
scttydb411's Avatar
is the boost dropping off at the upper end? if so it might just be the turbo running out of breath. if it's hot enough the boost charge will be slightly less too.
Old Oct 7, 2003 | 10:13 AM
no the boost was used to stay at 15 this is not the problem....
Old Oct 8, 2003 | 09:29 PM
accordfreak's Avatar
bump... did you fix your problem?
victoriasamantha
Jun 16, 2009 03:27 PM
pip9
Sep 14, 2004 02:29 PM
93TurboSi
Oct 16, 2003 06:04 PM
