smoke coming from valve cover breather filter???
Old 09-25-2005, 06:48 AM
the.hamburglar's Avatar
Default smoke coming from valve cover breather filter???
i have a small about of ble smoke being burned of and its coming out the my valve cover breather filter. its not that bad, just weird. any ideas what it is?
Old 09-25-2005, 06:58 AM
mike93eh
Guest
Posts: n/a
for starters...how about you take that stupid ricer filter off and hook it up like its suppose to be..
Old 09-25-2005, 08:27 AM
Default Re: (mike93eh)
what do you mean hook it up like its supposed to be? youd be stupid to hook it up to the charge pipe. anyways, she blew so i need a new motor now
1-180psi
2-160psi
3-40psi
4-100psi
think its alright to still bad and mess up the motor more. ill buy a new one in the spring. or is all that oil its buring going to mess up the turbo and map sensors. on second thought ill just park it.
Old 09-25-2005, 10:44 AM
hotimportcrx's Avatar
Default Re: (the.hamburglar)
blue smoke= oil.....oil out of breather=blowby...blow by= shot piston rings....
Old 09-25-2005, 10:46 AM
Default Re: (hotimportcrx)
and alot of times when u mess up your engine cylinders 3 and 4 usually go first....because it takes the longest time for the fuel to travel threw the rail to those cylinders....resulting in those cylinders leaning out before the others
Old 09-25-2005, 10:48 AM
no its gonna keep getting worse.....thats how mine was when i blew the rings...first it was a little then i riped it again...because i knew it was done...and it started shooting oil out the breather and out the exhause manifold all over the place
Old 09-25-2005, 11:19 AM
think the sleeves are ok? will i need to replace them
Old 09-25-2005, 11:26 AM
Day-DayC's Avatar
i saw this problem at ultimate speed shop when a car was on the dyno when they made a pass on the dyno smoke would come out of the breather port. saw the comp. i wold go with a set of new rings.how much boost are you running?
Old 09-25-2005, 11:31 AM
Default Re: (Day-DayC)
5psi
Old 09-25-2005, 11:43 AM
Day-DayC's Avatar
sleeves should still be good
Old 09-25-2005, 08:28 PM
5 psi your fine i was running 16 daily and mine are nice.....just get some aftermarket rods/pistons and run 10-12 psi daily and more when "you need to"
Old 09-25-2005, 08:36 PM
yeah but is it alright to get forged pistons and rods with the stock sleeves and valvetrain?
Old 09-25-2005, 09:30 PM
BCICAN
Dunc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">for starters...how about you take that stupid ricer filter off and hook it up like its suppose to be..</TD></TR></TABLE>
haha wow that was a really educated response (please note alot of sarcasism there)
Old 09-25-2005, 09:41 PM
Default Re: (Dunc)
yea...why not,,,you know how many ppl got stock sleeves...and valvetrain..with aftermarket rods/pistons
Old 09-26-2005, 02:13 PM
alot of people actually get aftermarket pistons and rods with the stock sleeves? it costs to much damn money to sleeve it. so id be alot with just pistons and rods? how much could i boost with 9:1 pistons and forged eagle rods?
Old 09-26-2005, 03:00 PM
Syner-G-Racing LLC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">blue smoke= oil.....oil out of breather=blowby...blow by= shot piston rings....</TD></TR></TABLE>
or cracked ringlands.
Old 09-26-2005, 03:52 PM
turbotime's Avatar
does the smoke come out of the breather all the time or just in higher rpms? is it alot of smoke or a little?
Old 09-26-2005, 04:04 PM
turbotime's Avatar
...cause light blue smoke comes out of my valve cover breather at high rpms 6-8k ish. I think its normal.. i mean that engine is hot under boost, some oil is bound to burn off.
i would comrpession and leakdown to confirm
can you see the smoke when your just driving? how do you know its smokeing from the breather?
Old 09-26-2005, 04:23 PM
Default Re: (turbotime)
didnt i tell you guys my numbers?
1-180
2-160
3-40
4-100
my motor is toast. it needs a rebuid, i did look above please close to the top
sohczcturbo
03-10-2007 10:13 AM
stegon78
04-11-2005 06:55 AM
djnikko
09-22-2004 08:47 AM
XBoostedAccordX
08-26-2003 10:33 AM
flat-blk-HB
06-17-2003 07:08 PM
Quick Reply: smoke coming from valve cover breather filter???
