Sleeving, some questions
Old Sep 14, 2002 | 08:14 AM
austrian type-R's Avatar
Default Sleeving, some questions
open or closed deck? Which is better, what are the pros & cons?
Brand? which one is the best bang for the buck? Golden Eagle is out of the game, cause they don't ship their sleeves.
I have a B18C5, how large can I go with the displacement to be safe? 1.9, 2.0 litre?
Where to get some JE pro series 9:1 oversized pistons, are they in stock anywhere?
What else so I have to take care when I sleeve the block? Do I need a different head gasket, how about the head studs, etc......
Old Sep 14, 2002 | 08:17 AM
Smashback's Avatar
Default Re: Sleeving, some questions (austrian type-R)
Aw, you don't want to ship your motor to the states and back? It can't cost that much!
Old Sep 14, 2002 | 09:42 AM
Default Re: Sleeving, some questions (mplex2000)
http://www.dartonsleeves.com/intro_02.htm
please help me eith that numbers on Darton's hp.
Which one is the correct sized sleeve for the biggest bore which is safe for 1.2 Bar boost. I wnat to run JE pro series pistons, what size do the pistons need?
Old Sep 14, 2002 | 10:04 AM
Default Re: Sleeving, some questions (C-man)
I make now 370whp and wanted to stay there. Nut since I need new pistons anyway I whought on sleeving the block to 2.0 litre. This ar is my daily driver.
The hp question is not as important than reliability. My eninge is already built with eagle rods, crower valve springs & ti retainers, JE pro series 9:1 pistons, Haltech eCU, 720cc injectors, cam gears, etc.........
[Modified by austrian type-R, 8:07 PM 9/14/2002]
Old Sep 14, 2002 | 10:39 AM
hehe, ARP head studs are already installed. Can I use the stock head gasket, or does bigger sleeves require a different head g?
Old Sep 14, 2002 | 10:45 AM
DLB1994's Avatar
yeh u got to get a Cometic headgasket for your bore size
Old Sep 14, 2002 | 11:03 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Sleeving, some questions (DLB1994)
Golden eagle sleeves and deck plate. 2.0 and longer rods =low/mid range torque. CHek my bio for my setup.
Old Sep 14, 2002 | 11:52 AM
ninesecrx's Avatar
Default Re: Sleeving, some questions (Civicdrgrcr)
I use benson/darton open deck sleeves on my race motor. Jojo Callos uses open deck on his race motors. Venom uses open deck on their motors as well. I think its the better all around design....Mike
BoiTypeR
Feb 11, 2010 01:16 PM
PowerHouse
Nov 8, 2004 05:43 PM
swlabhot
May 20, 2004 01:44 PM
quis23
Feb 24, 2004 05:11 AM
FastechAccord
Aug 27, 2002 01:21 PM
