H and F series overbore question...
Some guy on the Accord forum posted he had his f series bored .20 over. I thougth these motors didnt come with iron sleeves.???? Can you bore or even hone these blocks since h and f series blocks are designed alot alike?
Re: H and F series overbore question... (DLB1994)
He used the Race Engineering pistons and crower rods. But how do you bore a motor with no iron sleeves??
Re: H and F series overbore question... (EvoAccord)
to put forged pistons in any f or h engine u got to re-sleeve it
and u can bore it how much u want then
Is it possible to just replace the factory pistons with forged pistons and not hone or bore the block? Will you get a good seal for the rings?
If you can clean up the cylinders and stay within the F22 oversize bore limit (.25 over...85.250-85.260mm, .50 over...85.5-85.510mm).
Per honda factory manual...Reboring limit .050mm max
