Sleeving Q
Old May 20, 2004 | 10:48 AM
swlabhot's Avatar
Default Sleeving Q
NooB engine rebuild Q If I my B18C6 is bored out to 2 ltr does it need to be sleeved or can I get away without?
What size pistons would I need for this bore and would it have to be custom pistons or can I just get off the shelf larger bore pistons?
Old May 20, 2004 | 10:59 AM
PM-Performance's Avatar
Default Re: Sleeving Q (swlabhot)
if you wanna do it right sleeve it and over bore it. yes they can be off the shelf pistons.
Old May 20, 2004 | 11:07 AM
swlabhot's Avatar
Default Re: Sleeving Q (itr206)
I would love to sleeve it but as I'm in the UK, unfortunately the world of FI Hondas is in its infancy here and so there isn't any 'REAL' expertise in sleeving Honda blocks that I can call upon. Any other cars (ie, Evo, GTR etc..) there are PLENTY. So on my side of the pond I don't really have much choice.
Old May 20, 2004 | 11:09 AM
i wouldnt try to over bore your stock sleeves that much , youll be asking for trouble. why do you need 2.0 anyway ? you can make more than enuff power on 1.8
Old May 20, 2004 | 11:12 AM
b18bturbo's Avatar
i also dont reccommend to over bore a stock boosted more than 81.5mm at max. After you go past that point it will be like paper thin between the cylinders. The stock sleeves are strong to point. I would just try your best to buy a US block and swap it out
Old May 20, 2004 | 12:41 PM
swlabhot's Avatar
Default Re: Sleeving Q (b18bturbo)
I'm actually planning on just going stock bore 0.02" oversize but was just curious as to what my other options are and their adv/disadvantages. Thx.
Old May 20, 2004 | 01:44 PM
X-Mazda 3 Racer's Avatar
You can always add displacement using a stroker crank! That is an easy way to add more ponies to your set-up without sleeving. Crower and Eagle both have nice kits available.
But if you are going turbo, then add some more mm to your bore by sleeving. it is good insurance for you.
ludeking1007
Apr 8, 2010 09:15 AM
q8delsol
Nov 13, 2007 05:09 PM
sean-sports
May 27, 2007 11:07 AM
slammedef06
Sep 4, 2005 07:57 PM
turbo89civicb18hatch
Nov 8, 2004 04:42 PM
