sleeves or pistons and rods
Depends on what you're doing with the engine....sleeves aren't always needed nor is forged pistons and rods. What's your inteded use/set up?
At that boost level max you should be fine with just forged pistons and rods and maybe a block guard as long as the car will have decent TUNING. If you were mainly racing the car, sleeves would be a safer way to go but for street and strip use, what I said should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAMStudent »</TD></TR><TR><TD CLASS="quote">True, but if you are going to use a good quality
forged piston(JE, SRP, Weisco,etc.), you will have
to use a ductile iron sleeve.</TD></TR></TABLE>
I'm not sure I understand what you're saying since the stock cylinder sleeves are ductile iron and you certainly don't need to sleeve a block to run forged aftermarket pistons.
The stock sleeves in the b series Honda blocks aren't ductile iron. They are cast iron, but you are right in that you can run aftermarket enternals in a block with stock sleeves. Eventually you will want to sleeve it though. I think you ought to sleeve it first cause I have personally seen too many blocks come in our facility with cracked stock sleeves. Some are salvageable and some are not. Just do it right the first time and you wont have to worry about it.
Yes the sleeves are iron everyone knows that. John was saying that JE and Endyn both recommend that you run their pistons in Ductile Iron.
Bobby Snyder
Bobby Snyder
