Sleeves, Forged Pistons, and knock sensor
Old Apr 7, 2003 | 05:18 AM
TURBO-JET LUDE's Avatar
Default Sleeves, Forged Pistons, and knock sensor
Is it common for the stock konck sensor pickup knock and retard the timing after building the H22 block with sleeves and forged pistons? I have run a stock H22 @ 8psi for over 1 year without detonation. I recently built the block with 9.0:1 JE's, and this started to happen after high rpm runs. Oh yeah, I have not yet raised the boost, and fuel system is the same as before, and runs rich right through.
Anybody experience this?
Old Apr 7, 2003 | 06:20 AM
LEON's Avatar
Default Re: Sleeves, Forged Pistons, and knock sensor (TURBO-JET LUDE)
Could be piston slap causing the noise in the cylinders that the stock knock sensor is hearing. I know GruvyTune had a similar problem using a J&S on his built GSR motor.
iheartmyej8
May 13, 2006 09:57 PM
I makes it RAIN
10
May 2, 2006 04:32 AM
fastludeh22
Oct 26, 2003 08:21 AM
IloveNewt
Jun 19, 2003 12:24 PM
Firedrake
Oct 31, 2002 05:29 PM
