knock sensor, ls/vtec
Old May 13, 2006 | 12:37 PM
iheartmyej8's Avatar
Default knock sensor, ls/vtec
i have a built ls block: srp forged pistons eagle rods. i need to know if i can even run a kncok sensor? would the forged pistons make the knock sensor go crazy? its a 0bd0 pr3 ecu, stock.
Old May 13, 2006 | 04:32 PM
mr.beeks's Avatar
Default Re: knock sensor, ls/vtec (iheartmyeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyeg &raquo;</TD></TR><TR><TD CLASS="quote">i have a built ls block: srp forged pistons eagle rods. i need to know if i can even run a kncok sensor? would the forged pistons make the knock sensor go crazy? its a 0bd0 pr3 ecu, stock.</TD></TR></TABLE>
this is a good one..
detonation is what causes the knock sensor to triger
and yes you need it so your ecu (unless modify) does not throw a CEL, who would like to run without the knock sensor on built engine?
Old May 13, 2006 | 09:39 PM
Default Re: knock sensor, ls/vtec (mr.beeks)
thanks. i dont too much on the whole motor stuff.
Old May 13, 2006 | 09:57 PM
gsr dood's Avatar
yeah i put a knock sensor on my built ls-vtec and the CEL for my sensor would come on after like 2 minutes of driving. its def gunna sense knock.....wat i did was get it crome tuned. not even that i would go on ebay and there a guy who sells stock chips and u have the option to remove vtec. the chip and eprom install kit will run u about 30$ and all u need is basic soldering skills or bring it to a local electrician which should be a cheap quick job.
hondakrazy
Nov 14, 2008 10:42 AM
1.5boosted
Dec 14, 2007 01:45 PM
ls weez
Jun 10, 2006 02:01 PM
Big Dick Bandit
Sep 28, 2003 04:54 PM
untitled
Aug 9, 2003 08:07 AM
