Sleeves
Old Sep 14, 2009 | 02:20 PM
civicracer1997's Avatar
Default Sleeves
I am planning a build for a B16A2 here in the near future and my intentions are to go turbo on this build. From my research over the years I have come to learn that all the manufacturers are about the same. My question is should I run dry sleeves or wet sleeves. I plan to run anywhere between 15psi and 28psi boost. Any help would be great. Thanks in advanced.
Old Sep 14, 2009 | 02:37 PM
narfdanarf's Avatar
Default Re: Sleeves
It doesn't really matter as long as you go with a reputable company/installer. I personally went with GE because they were the cheapest for what I wanted, and it just so happens they have one of the best track records out there
Old Sep 14, 2009 | 03:18 PM
Default Re: Sleeves
For those of you who cant read I dont care which manufacturer is the best blah blah blah. I wanna kno what the difference is really between running dry sleeves or wet sleeves. Thats all I want to kno right now. I will decide on the brand later.
Old Sep 14, 2009 | 03:40 PM
Garage 808 Hatch's Avatar
Default Re: Sleeves
Wet sleeves will be thicker, as they eliminate the aluminum around the sleeve, thus being stronger
Old Sep 14, 2009 | 04:30 PM
Default Re: Sleeves
Awesome thats kinda what I wanted to kno.
Old Sep 14, 2009 | 05:06 PM
blinx9900's Avatar
Default Re: Sleeves
Wet, IMO dry sleeves are just as strong as OEM, there good for about 20psi...
Old Sep 14, 2009 | 06:29 PM
96 GSR-T's Avatar
Default Re: Sleeves
So your saying AEBS and ERL Sleeves with the large upper "blockguard" are only good for 20psi??
Old Sep 14, 2009 | 06:46 PM
narfdanarf's Avatar
Default Re: Sleeves
I gave you all the pertinent information required for this topic in the first reply. I will state again: It doesn't matter.
edit: because you seem to be dense and most assuredly this will aggravate you since you think you're question isn't being answered, I will tell you installation (machining) is what matters. They are both designed to do the same thing, and the metal is designed to withstand things that the stock sleeve can't.
Old Sep 14, 2009 | 07:21 PM
blinx9900's Avatar
Default Re: Sleeves
Was referring to the Darton Open Deck Dry sleeves, last i checked they were rated for 20psi.
Old Sep 14, 2009 | 08:24 PM
Default Re: Sleeves
wouldnt those be wet sleeves? as they actually see the coolant, and dry sleeves are just the shitty reliners?
Old Sep 14, 2009 | 09:06 PM
96 GSR-T's Avatar
Default Re: Sleeves
To be honest IDK, I have the old school GE Godzilla sleeves that have a full open deck with just a brace down low and a machined egde for the brace/sleeve to rest on, I always considered them "wet sleeves" because at the top its just sleeve and fully surrounded by coolant and the enclosed designs "dry sleeves", I could very well be mistaken I guess.
Old Sep 14, 2009 | 09:49 PM
narfdanarf's Avatar
Default Re: Sleeves
Wet sleeves, = coolant touches them
Dry sleeves = usually installed into oem casting, which separates sleeve from coolant.
typically wet sleeves have much higher power/pressure ratings, though the dry sleeves have also proven to be very worthwhile. I would never run them, but that doesn't mean they aren't any good, and for the OP's purposes, either would suffice more than likely.
Old Sep 14, 2009 | 10:37 PM
91redteg's Avatar
Default Re: Sleeves
everyone over here uses the eagle sleeves. the obvious choice would be wet sleeves
oday
Jun 5, 2022 01:00 PM
ttracing03
Apr 1, 2006 02:43 PM
blueb18c
Jan 26, 2006 05:56 PM
TXcivic96
Sep 24, 2004 11:47 AM
Twenty36_1
May 29, 2003 07:36 AM
