sleeved ls vtec build need help!!
Old Mar 25, 2014 | 04:35 PM
da love's Avatar
Default sleeved ls vtec build need help!!
Was going take my block to richtuned tomorrow to have it sleeved, I plan on using arp head studs for the block, do I need to modify the block In anyway to use studs please help
Old Mar 25, 2014 | 04:40 PM
WackyRicanMan's Avatar
Default Re: sleeved ls vtec build need help!!
What head are you using?
Here is the info I believe you need.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/arp-head-studs-ls-vtec-2911466/
Originally Posted by Garrett
OEM B16A : 6.85"
ARP B16A : 7.125"
OEM B18C1 : 6.75"
ARP B18C1: 7.250"
on ls or b20vtec, I always use b16a, or b18c, since they are cheaper than the lsvtec or b20vtec ARP special ones
Old Mar 25, 2014 | 05:03 PM
da love's Avatar
I will be using a gsr head, thank you.
Old Mar 25, 2014 | 05:17 PM
da love's Avatar
I'm kinda new at this engine building thing any help would be awesome, feel free to pick apart my plan, I would love to know everybody's opinions on my setup, and if I'm missing anything please let me know this is my first motor build trying to do it the right way the first time. For the head I plan on using skunk 2 pro series 2 cams, springs, retainers, lost motion assembly's and supertech stainless valves. For the block I'm kind of undecided I don't know what pistons and rods to use I want to make at around 400 horse reliably and steet driven.I am going to have golden eagle sleeve it through richtuned in auburn wa.
Old Mar 25, 2014 | 06:06 PM
blackeg's Avatar
you most certainly do not want to use pro2 cams...type r or tuner1 are more than enough cam
you also dont need stainless valves oem valves work more than fine they are stronger than you think.
i recommend using a bore of 84mm you will love the extra tq and displacement.
pretty much pick any name brand forged piston try and shoot for a compression ratio between 9 and 10:1. if you use cp pistons i would make the piston to wall more like .004 most others can run with .0035". cant go wrong with eagle rods but i hear the brian crower rods weigh a bit less and are very close together in weight between rods if i remember correctly.
there is soo much more too it like drivetrain, turbo setup, fuel and engine management. dont be afraid to search and read like crazy
Old Mar 25, 2014 | 07:00 PM
da love's Avatar
Why not pro 2s to much for the street? I have heard that they have a rough idle quality for a daily driver, but make pretty good power. Isn't the max bore on ge sleeves 84mm, I planed to use a hondata s300 for engine management and a aftermarket fuel pump, I'm not really working on a budget I plan on taking my time so I can get it right, is their anything else I should have done to the block while I have it sleeved I planed on getting it o ringed
Old Mar 25, 2014 | 07:09 PM
Click on my build in my sig, I am building a stock sleeve 400whp LS/VTEC right now.
81.5MM LS Block Stock sleeve
9:1CR Mahle PowerPak Pistons
Eagle Rods
CTR B16 Head w/ GSR Cams (Looking for ITR or Pro 1s)
ARP Head studs
Custom T3 Manifold
Garrett T3/TO4E .57 trim .63 a/r
Tial 38mm wastegate
3" Exhaust with a resonator and Vibrant muffler
JDM GSR Trans
Competition Stage 3 Clutch
Competition 12lbs flywheel
btw here is a good read. Listen to what the shodan says. He is a god on here.
https://honda-tech.com/forums/forced-induction-16/skunk2-pro2-cams-good-turbo-setup-2909592/
Old Mar 25, 2014 | 07:32 PM
TheShodan's Avatar
Moderator
Eagle Rods
ARP Head studs
Custom T3 Manifold
Tial 38mm wastegate
JDM GSR Trans
https://honda-tech.com/forums/showthread.php?t=2909592
That read is a little outdated, actually. Some great strides with some different camshaft companies have proven a lot of that wrong over the last 2.5 years.
Old Mar 25, 2014 | 07:39 PM
mechanix619's Avatar
Keep things simple. For 400 HP you don't need to have the block sleeved. Also, if you're dead set on sleeves then have Golden Eagle do the machine work. I'm not saying a local shop can't do it but GE would be the preferable choice. Springs and retainers would be nice. Stock valves will work fine. Stock pistons and rods would also work. ARP hardware would be appropriate.
Old Mar 25, 2014 | 08:33 PM
da love's Avatar
Reliability wise wouldn't sleeving be the best over stock sleeves can they really handle 400 hp ?
Old Mar 25, 2014 | 08:41 PM
Reliability is in the tune.
Old Mar 25, 2014 | 09:09 PM
turbohatch96y7's Avatar
Eagle Rods
ARP Head studs
Custom T3 Manifold
Tial 38mm wastegate
JDM GSR Trans
Attachment 526254
Old Mar 26, 2014 | 04:21 AM
Originally Posted by turbohatch96y7
Old Mar 26, 2014 | 07:26 AM
TheShodan's Avatar
Moderator
Agreed. I'm good, but God-like, ummm.. nah.. But thank you... (I think..)
Charbonowsky
Feb 7, 2012 06:31 AM
96Spec Ek
Feb 6, 2009 08:12 PM
91redteg
Nov 8, 2007 03:48 PM
XSIWANNAB
Apr 11, 2005 09:00 PM
IgniteTeg
Aug 5, 2001 11:22 PM
