Sleaving
Old Oct 16, 2002 | 03:31 PM
Fatty_1775's Avatar
Default Sleaving
Is it necessary to sleave your block if you are running 9 and under psi on a b16?
Old Oct 16, 2002 | 03:45 PM
Adriano's Avatar
Default Re: Sleaving (import_racer)
nope. as long as you got enough fuel in the engine, you should be fine. I heard of some people running 12lbs with stock internal with some tuning.
Old Oct 16, 2002 | 04:01 PM
PrecisionH23a's Avatar
9psi on stock internals is kind of pushing it on stock internals, but as long as you have it properly dyno tuned. i would recommend having a nice fuel management system, v-afc works but the hondata is your best bet. by the way, its sleEving.
[Modified by GudeH23a, 8:02 PM 10/16/2002]
Old Oct 16, 2002 | 08:15 PM
HybridKOOP's Avatar
Default Re: Sleaving (GudeH23a)
Old Oct 16, 2002 | 09:52 PM
Fatty_1775's Avatar
Default Re: Sleaving (HybridKOOP)
Thanks!!! I did not know how to spell it!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 17, 2002 | 06:03 AM
KoRE's Avatar
Default Re: Sleaving (brryder)
lol i did that without tuning and i burnt a piston lol
tuning is very important
Old Oct 17, 2002 | 10:17 AM
GM2000ITR's Avatar
New User
How would you guys feel with forged pistons/rods and Blockguard in stock sleeves holding up to 9-12 psi?
Old Oct 17, 2002 | 10:57 AM
FOrSfEd's Avatar
Default Re: Sleaving (GM2000ITR)
I've seen 18+psi on a stock block. It's all about tunning.
Lee
Old Oct 30, 2002 | 03:15 PM
Fatty_1775's Avatar
Default Re: Sleaving (ALLsh0w)
Exactly how do you tune a car? What is done? I always here people talk about tuning cars and no one has exactly mentioned what is done.
Old Oct 30, 2002 | 03:19 PM
you go to a dyno and have it monitored with a wideband 02 sensor. Your a/f ratio is tuned to where it will produce the most power. Ignition values are also adjusted to produce power.
http://www.hondata.com/techtuneboost.html
for more info
Old Oct 30, 2002 | 03:28 PM
speedworks's Avatar
awesome avatar, i just hope that is not your sister
Old Oct 30, 2002 | 04:39 PM
DeepSi's Avatar
Default Re: Sleaving (speedworks)
LOL
Old Oct 30, 2002 | 04:58 PM
EVOCELICA's Avatar
New User
depends what turbo you are using, i have a t3 and am able to push 9 psi on the stock block without a problem
Old Oct 30, 2002 | 05:06 PM
Quick 200k Mile Motor's Avatar
I thought there were rules to avatars. I got a pic of me diving on the muff. ..guess I might as well put that as avatar.
mugencivic94
Dec 29, 2005 08:12 AM
Ya@inlinePRO
May 17, 2003 07:57 PM
TwistedHatch
Dec 19, 2002 05:24 PM
tygsr
Jul 6, 2002 12:16 PM
The Punisher
Aug 26, 2001 07:46 PM
