sleave question?
Old Mar 18, 2004 | 04:43 AM
b16 matt's Avatar
Default sleave question?
If my sleaves are perfectly fine, but my block leaks oil into the water jackets. can I have my sleave pressed out of one block and into another?
Old Mar 18, 2004 | 04:46 AM
Adi Radoncic's Avatar
On Fire!
Default Re: sleave question? (b16matt)
u sure its not your headgasket?? not sealing up correctly?
Old Mar 18, 2004 | 04:54 AM
b16 matt's Avatar
Default Re: sleave question? (newgsr)
i Dont know I have changed it. It's a cometic. I dont know whats going on just alot of smoke and stinkyness.
Old Mar 18, 2004 | 05:15 AM
b16 matt's Avatar
Even if it is the gasket, can you re-use sleaves? I have been wondering.
Old Mar 18, 2004 | 07:52 AM
m R g S r's Avatar
If they are stock sleeves its not worth it. But I don't think that you can re-use them if they are aftermarket.
Old Mar 18, 2004 | 08:10 AM
b16 matt's Avatar
Default Re: sleave question? (m R g S r)
they are GE
Old Mar 18, 2004 | 08:23 AM
b18bturbo's Avatar
if the sleeves are ge they cannot be really transferred but you can send the block back to GE and get them to sort it out. It should not leak at all Vince is good about thatits could possibly just needs to be decked even and ne wgasket
Old Mar 18, 2004 | 08:27 AM
G
sh!t happens.
Default Re: sleave question? (b18bturbo)
send it back to ge and then get it sleeved by benson...lol
Old Mar 18, 2004 | 03:22 PM
93LSivic's Avatar
If you had Dartons you could. Im sure you could send it back and get *** raped by GEM and they will re-sleeve another block for you. But, my question is this. Is it possible there is a defect in the sleeving and is that why you have oil in your coolant? Hmm, sounds like a dropped sleeve. If you want more info on headaches like this contact member Boostfed here on h-t.......he'll tell you lots about GEM blocks and his experiences with them.
Then again it could just be a headgasket problem, who am I to know
RPMvulocity
Dec 28, 2012 09:42 AM
Da9_Rider
Oct 23, 2007 02:00 PM
VNTEC
Dec 22, 2003 12:46 PM
98Psi ITR
Mar 27, 2003 10:02 AM
EFing8
Jan 27, 2002 01:20 PM
