slave cylinder in the way?
Old Mar 3, 2004 | 11:50 AM
monicle's Avatar
Default slave cylinder in the way?
Ok so Im finally installing my turbo. I had to cut the tab off right under the B18C stamp to get the turbo to fit on and now it seems that the slave cylinder may be in the way. Is there a way arround this?
Old Mar 3, 2004 | 11:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
Is it the slave cylinder itself or the hard line?
If it's the line, you can get a steel braided line for more room. If it's the slave itself, I don't know. You could always get a cable tranny and a HASport cable to hydro conversion!
Old Mar 3, 2004 | 11:53 AM
norcalcrx's Avatar
Default Re: slave cylinder in the way? (monicle)
Use a 45 degree rubber elbow. We had the same problem on one of our cars. If you are cheap you can just use 2 pieces of mesh screen with a stocking in between clamped to the inlet.
Old Mar 3, 2004 | 12:18 PM
monicle's Avatar
Default Re: slave cylinder in the way? (norcalcrx)
heh nothing about this project have I gone cheap on. What thread size are on the ends of the hardline? Ill probably just do a mesh line in addition to the 45degree
Old Mar 3, 2004 | 03:29 PM
DaX's Avatar
DaX
Loved
Community Favorite
Contact Flamenco-T on here for the clutch line kit.
Old Mar 3, 2004 | 04:15 PM
JDMCRX's Avatar
Default Re: (DaX)
i had the same prob u got to use a 3"to 2.5" and then u can go 2.5" to 3" connector.
Old Mar 3, 2004 | 06:44 PM
monicle's Avatar
Default Re: (JDMCRX)
but wouldnt a bottle neck in there kinda defeat the purpose of a 3" inlet?
Old Mar 3, 2004 | 06:47 PM
turbo96wr's Avatar
Default Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">but wouldnt a bottle neck in there kinda defeat the purpose of a 3" inlet?</TD></TR></TABLE>
you could use an inverted flair with -3 an on the other side.
Old Mar 3, 2004 | 08:20 PM
S2KP's Avatar
i had that same problem. I used a 90 degree and came up with my own intake pipe
b20vtecGSR
Apr 21, 2019 12:07 PM
sideswiped
Jun 13, 2010 01:35 PM
underpressure02
Apr 2, 2006 05:26 PM
integra6650
Dec 30, 2002 02:18 PM
