Skunk valves
Old Apr 7, 2005 | 02:06 PM
Rob1242's Avatar
Default Skunk valves
Just wondering if any one can help me out. I bought a fully built b18c1 head for all motor for a decent price: port and polished, skunk springs, skunk retainers, skunk valves, skunk cam gears, stock cams. Now I decided to go turbo and have built my bottom end with Golden eagle sleeves, 9:1 JE pistons, and eagle H beam rods. I was wondering if the head with skunk all motor valves could be used with a turbo setup? Any help would be appreciated, thanks.
Old Apr 7, 2005 | 02:21 PM
adictionbass's Avatar
Default Re: Skunk valves (Rob1242)
the only difference i can see in them is that there are the regualar dished valves, and then theres high compression vales which a basically flat.
The only difference i think they are going to make is a little higher compression. I dont have any clue how much. I cant see them not okay for boost, just higher compression.
Boostedcivicsi's Avatar
the skunk valves can be used, but will raise compression slightly. you would be better off getting a flat based valve which would work better with a turbo setup.
Old Apr 7, 2005 | 10:25 PM
earl's Avatar
you will be fine with that head, dished valves or flat head valves.
Old Apr 8, 2005 | 04:19 AM
Rob1242's Avatar
Default Re: Skunk valves (earl)
Alright, thanks guys for all your help!
99siRACER
Jul 1, 2011 05:35 AM
importfan2
19
Oct 21, 2008 06:18 PM
BMO98GSR
Dec 16, 2007 03:24 PM
redhanyo
12
Apr 15, 2006 07:39 PM
9T6EJ8
May 9, 2004 10:19 PM
