side effects of a WBO2 exhaust leak?
Like the title says, my exhaust is leaking prior to the wideband, i was afraid of breaking the bolts (like i already did), so i just snugged it and tac welded them in place After doing so, i notice a minor leak when feeling around the seems, it doesn't seem to terrible, just enough that i know it's there.
I searched and didn't find much, someone enlighten me a bit?
Re: side effects of a WBO2 exhaust leak? (O16581724 5 2 5)
its gunna read lean, i know i had a leak on my downpipe before my wideband sensor and i knew the tune was fine but all of a sudden my a/f ratio would climb up 2 whole values lol, i figured it was the leak causing it, and it was
Re: side effects of a WBO2 exhaust leak? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">its gunna read lean, i know i had a leak on my downpipe before my wideband sensor and i knew the tune was fine but all of a sudden my a/f ratio would climb up 2 whole values lol, i figured it was the leak causing it, and it was </TD></TR></TABLE>
Same here. Do it right and get it welded
Re: side effects of a WBO2 exhaust leak? (adseguy)
Can't really weld it, i welded the bolts to the downpipe because they kept coming out.
I thought i had it sealed, welded it in place, started it again, air starts puffing out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">Can't really weld it, i welded the bolts to the downpipe because they kept coming out.
I thought i had it sealed, welded it in place, started it again, air starts puffing out.</TD></TR></TABLE>
you're going to have to; contaminated exhaust doesn't respont linearly; it will be of more in some places than others; it makes tuning incredibly difficult to impossible. I had a small problem like that but fixed it.
good luck
good luck
Re: side effects of a WBO2 exhaust leak? (Pay2play killa)
I caked on some of the exhaust repair stuff, seems to have sealed it, i feel no air leaking.
Slowboy!
16
01-12-2006 09:58 AM
douglaslovin
13
09-16-2005 08:57 AM
